Old 06-13-2017, 11:44 AM
DavGoodlin's Avatar
Motorola Minion
Hallicrafters 602 acquired
12 inch round, a big screen for a Hallicrafters anyway and also unlike the famed push-button models, has some kind of continuous tuner that rotates between detents for channels.
This set was found in an attic of a house in the heart of coal country (initially served by only one VHF channel until UHF stations popped up in 1952-3) and brought to work by a friend of the original owner. I had been working on it over lunch-breaks where he and I replaced all the wax-paper and electrolytics. Since he is out on extended disability, he asked me to just take it home.
From VintagePC's thread on his Hally 815, I deduced there are quite a few issues beyond just the caps in this set as well. We did get a very dim but full raster, so its not hopeless but it has some funny symptoms.
-Dave G
Old 06-13-2017, 12:28 PM
Attachment 194916
What other symptoms is the set exhibiting, and did you check the CRT? The latter could be the reason for the dim raster, although I would look elsewhere first. The horizontal output tube could be so weak it is just barely working. In a set this old (late 1940s-early 1950s), this seems very likely, but again, I would check the CRT cathode emission before doing anything drastic. Of course, if the set is using a CRT brightener, the tube is just about shot anyway and should be replaced.
Old 06-13-2017, 12:31 PM
DavGoodlin's Avatar
Motorola Minion
Originally Posted by Jeffhs View Post
Did you check the CRT? This could be the reason for the dim raster, although I would look elsewhere first. The horizontal output tube could be so weak it is just barely working. In a set this old (late 1940s-early 1950s), this seems very likely, but again, I would check the CRT cathode emission before doing anything drastic. Of course, if the set is using a CRT brightener, the tube is just about shot anyway and should be replaced.
Yes, the 12RP4 had a bright-ner on it and tests weak. I also get red plate on the video amp 12AU7 when I turn up to contrast control.
-Dave G
