Old 06-19-2017, 03:38 PM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
Worth getting?
A roundie at an upcoming estate sale. Should I try to get it?
Old 06-19-2017, 04:04 PM
If the price jibes with the CRT/general condition, why not?
I know I've seen that TV mask before....I wanna say it's Curtis Mathes. If I'm right then it is an RCA clone in the TV section, and a respectable CM designed audio system.
Old 06-19-2017, 04:50 PM
If you can, grab those rabbit ears in the window too! Brass rods, no chrome. Great antenna - we used one for bench use until '80, when we got cable and used only the outdoor antenna for OTA checks of consoles.
USN RET 22YRS (Avionics/Cal)
Old 06-19-2017, 06:51 PM
WISCOJIM WISCOJIM is offline
They must have been into radio/TV/hi-fi looking at the other stuff at that sale.
https://www.estatesales.net/CO/Denver/80212/1560885
Old 06-19-2017, 07:12 PM
Tom S's Avatar
Tom S Tom S is offline
where is this at. If you don't I will if it's close. Damm I want a CM
Tom Smrz
Old 06-19-2017, 07:16 PM
The link to the sale is in the post just before yours.
Old 06-19-2017, 09:46 PM
I believe you are correct. It's not too noticeable in the photo, but there is a Curtis Mathes badge on the CRT mask, and the control panel layout all but screams C-M.
The rabbit ears antenna may not be worth anything, as I think one of the "ears" (VHF dipoles) are missing. If the antenna is intact, however, with both ears, then by all means grab it when you pick up the TV. This type of indoor rabbit-ear antenna, which was made by Spico, is not terribly common these days (it dates to at least the early 1950s), so if you can find one it will be a nice piece of TV history.
Old 06-19-2017, 10:00 PM
SpaceAge's Avatar
Ok, I'll see what I can do...
Old 06-20-2017, 12:11 PM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
I bought one just like that in Indianapolis, like Sears it's a cheap version of the RCA ctc 15. It has a plastic bezel around the crt vs. Metal used by Rca and Magnavox, my guess is the set was built by Wells-Gardner.
[IMG]
Old 06-20-2017, 03:51 PM
DavGoodlin's Avatar
Motorola Minion
The console radio is a 1937 Philco 37-650 but its in such shape that $20 would be high
-Dave G
