Old 07-02-2017, 01:50 PM
Adam's Avatar
Adam Adam is offline
Admiral 6S12
I got the radio working great on this, but have problems with the record changer. Looking in the second pic, the rod in the center hooks to those two on each side with 2 belts. The two rods on either side are geared down, one for 33 the other for 45. The idler wheel contacts the center rod directly for 78 speed, while the whole platform those other 2 are mounted on rotates either way causing the idler wheel to contact instead the rod on either one or the other side for 33 or 45. The position it's in in the picture is for 45. I need the belts, anyone know if these are even available, or if there is a suitable replacement around somewhere?
Old 07-06-2017, 09:50 AM
Bill Cahill's Avatar
Super Moderator
Post
Is that the one with 2 smaller cams that take a small flat belt?
Please join my forum.
