Old 07-03-2017, 11:48 AM
Freebee JVC 32" 2006 model set.
One of my neighbors at my workshop, dropped off a like-new condition, JVC set. It even included the original remote, but too early of a model for a DTV tuner. It works fine with an Insignia DTV converter.
My big problem is, I can't get purity in the upper right corner. The CRT is a USA Philips EIA 312, Sylvania. The yoke is an impressive one, totally potted with some kind of a convergence assembly?
Someone like Zeno, who worked on this newer stuff, please advise.
Too F'in heavy and too nice to scrap!
Old 07-03-2017, 03:25 PM
A very nice set, we sold JVC for about 8 yrs after all but
dropping Zenith. The only bad thing was the power supply,
way to complex & lots of SMD's.
First be sure its not near something magnetic.
Next check for PC cons in DGS, DGS relay if it has & be sure
the thermistor isnt broken.
Next give a real heavy manual DGSing.
If no joy get some small correction magnets off a junker
or even refrigerator door magnets. In TV's they are usually
small discs taped down or V shapes like on Thompsons.
Put up a pure single blank raster ( green usually used on in lines).
Place on bell near "blotch" move around AND rotate. Unless the
shadow mask has loosened that should do it.
BTW look in the set & see if one fell off ! You often find them
or yoke wedges laying on the chassis.
GBA ! LFOD !
Old 07-06-2017, 11:14 AM
GBA ! LFOD !
Thanks Zeno!
I took the back off this heavy beast and there is absolutely no dust!
It really looks like a complicated mudder. After running it, I discovered impurity in both upper corners.
There is some real different components on the CRT neck, totally different than even the 27" and smaller models.
The set was brought to me, on a pallet, face down using a fork-lift.
I have to get back to it.
Old 07-06-2017, 11:45 AM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
Thanks Zeno!
I'd like to see what's in this thing but I have no idea what to look for. All I've seen in those post-Y2K sets is a circuit board, speakers and a handful of wires.
Old 07-06-2017, 04:29 PM
Hope the shadow mask didnt break loose in transit.
Extra stuff on CRT is probably SVM or Scan Velocity Modulation.
First used by Sylvania IIRC. On high end sets. Actualy slows or
speeds the beam to make a sharp transition from dark to lite
etc. Has a PCB & a little yoke.
Old 07-07-2017, 10:59 AM
I quoted the year improperly! It's a 2002 model. I always wanted to be able to post pictures of lot of the interesting rubbish, I possess. I have to get to work on it.
Old 08-07-2024, 01:42 AM
james4 james4 is offline
The 2006 JVC 32" Freebee model offers reliable performance and solid picture quality for its time. Ideal for basic viewing needs, it stands as a dependable, no-frills TV option.
spelling bee answers
Old 08-08-2024, 03:03 PM
kf4rca kf4rca is offline
25vczp22
I bought a 25VCZP22 from a local rebuilder called Actron (later bought out by Video Display). It was only $100 which I thought was a good deal since new tubes were $150 at the time. It was for a Heathkit that I had purchased the kits from a veteran who had lost the VA accreditation for the correspondence school he was in. So, he never got the CRT.
Anyway, I was never able to get the purity set up in the lower right corner. I got it as best I could and surmised that the shadow mask was bent. On most scenes you don't notice it. Otherwise it looks good like any Delta gun does.
So, I guess you get what you pay for.
