Old 10-07-2017, 09:00 PM
Anyone have a Motorola SAMs Set 122 folder 5
I just want to know the value and wattage of two high watt resistors , one connects from one pin of an electrolytic to another electrolytic , the other from electrolytic to I think the power transformer.
Thanks
Old 10-07-2017, 11:02 PM
Kevin Kuehn's Avatar
Workin' Late Again
R88 5W
R89 10W
R90 2W
Old 10-08-2017, 01:29 AM
Kevin thanks but what are the values of them , the picture you have a link to I can see but not clearly , it says I have an unsupported browser.
Mike
Old 10-08-2017, 01:35 AM
Workin' Late Again
Old 10-08-2017, 01:38 AM
Workin' Late Again
Left to right they are 1.5K @ 2W, 375Ohm@ 10W, 5K@5W
Old 10-08-2017, 01:51 AM
Workin' Late Again
Fixed above link to go directly to image.
Old 10-08-2017, 02:57 AM
Kevin , thanks I can see it now.
Is the 10watt resistor part number 700782 ?
Old 10-08-2017, 09:31 AM
Workin' Late Again
Yes, with the exception Sams lists a 17K prefix.
Old 11-15-2017, 12:50 AM
I know have it recapped and thanks Kevin for the assistance with the resistors , I powered it up and there is no vertical sweep , is this Set similar to chassis ts-95 ?
If so I can go by that schematic to work on the vertical , link below to the service manual.
http://www.earlytelevision.org/pdf/M...94-TS95-v2.pdf
Mike
Old 11-15-2017, 11:11 AM
Workin' Late Again
Give me a couple hours and I'll scan Sams 122-5 for you. PM me your email and I'll send it when it's ready.
Old 11-15-2017, 04:48 PM
Workin' Late Again
I also forwarded the Sams 122-5 to the ETF so Steve can post it if he wishes.
