Old 10-11-2017, 09:40 AM
4thdoctorwho's Avatar
4thdoctorwho 4thdoctorwho is offline
Eico 147A screw size question
I need to replace the screws that fasten the front plate to the enclosure.
After looking through the manual, the parts list does list a bunch of screw types like #6-32 X 1/4.
However, the screws I need are listed as #6 P.K.
I have no idea what "P.K." means. Does anyone know what #6 P.K. means?
Thanks,
Tony
Old 10-11-2017, 10:03 AM
N2IXK's Avatar
N2IXK N2IXK is offline
Technohippie
This is a self tapping sheet metal screw. The "PK" comes from Parker Kalon, the original manufacturer.
Old 10-11-2017, 10:10 AM
Thanks for the reply.
It's strange that they list the screw sizes for all the other screws but for these 9 screws the manual only shows P.K. instead of the actual screw size.
Anyway, appreciate the answer.
Old 10-12-2017, 10:33 PM
Kevin Kuehn's Avatar
Workin' Late Again
#6 designates the diameter of the screw shank. Since they only hold the front panel the length and threads per inch isn't too critical. Simply try some #6 sheet metal screws long enough to go through both the front panel and into the cabinet.
Old 10-13-2017, 05:01 AM
Yeah, I know. Thanks for your input however. I was mainly curious about the "P.K." designation as I have never seen that before. So now I know that is/was a manufacturer and it denotes a self tapping type of screw.
