Old 10-26-2017, 12:09 AM
reeferman's Avatar
TV as light source?
Update. Solved. See below.
Samsung UN55J6200 LED TV.
Yep, the thread below this one.
The screen turned out to be bad, so I figured the set could be used as a light source if I removed the damaged screen. Right?
I removed the screen, and oh what a light source! Only problem is it flashed a few times then quit at the 2 minute mark. Having a second set of boards, I installed them (the T-con board had no screen to attach to) and the same thing. The screen lights up, then flashes a few times, and is dead by the 2 minute mark.
Any ideas??
Thanks
