Old 10-26-2017, 06:44 AM
treehouse391 treehouse391 is offline
Question Video signal to TV with only "External Antenna" Jack?
Hi all;
I'm a little new to vintage televisions, but would like to know what options might exist to feed an early transistor TV (1970s) with a video signal, if it only has an "external antenna" jack.
In trying to recreate a period-specific display, I need one of these older TVs to be displaying video coming from a computer. I have an older computer that can give me a composite signal from its graphics card (RCA jack), but how do I get that onto the older TV? What can I feed to the external antenna jack?
Many thanks,
Tim
Old 10-26-2017, 07:18 AM
Celt's Avatar
Celt Celt is offline
Peanut Head
You will need to get a modulator, which will transmit on Ch. 3 or 4. Should be easy to find on the bay.
Old 10-26-2017, 07:26 AM
Ah, thanks Celt... I'll look around. I figured it was something quite straightforward.
Old 10-26-2017, 07:28 AM
Modulator your best bet. Adding jacks doable but not
worth the effort. Gotta be sure its not a "hot" chassis
first but most will be........
Old 10-26-2017, 07:46 AM
Thanks, Zeno. Yes, I was hoping only to feed a signal to the external antenna jack. And a modulator that gives me a CH3/CH4 signal I gather will do the trick.
