Old 12-09-2017, 12:00 PM
Help to ID Antique Tube Tester
Any idea who made this?
Old 12-09-2017, 02:28 PM
WISCOJIM WISCOJIM is offline
A lot of those early ones you could only find the name and model on the meters themselves. Here's an example of that:
Can't tell what you have in that picture.
Old 12-09-2017, 08:21 PM
I found out it a Readrite Model 700. Circa 1925.
Old 05-12-2018, 01:36 PM
BBTV BBTV is offline
Technically known as a “Set Tester”. You would remove a tube,plug in the tester to the socket,and then plug the tube in. You could then read out all the voltages present. The manufacturer may have put their name on the meters....can’t tell due to photo resolution
