Old 04-03-2018, 09:02 PM
Wind157 Wind157 is offline
Tube question
Think I found my trouble. Does a 1b3gt tube have any visible glow?
Old 04-03-2018, 09:48 PM
Kevin Kuehn's Avatar
Workin' Late Again
It's very difficult to see it glow.
Old 04-03-2018, 10:09 PM
Darn, thought I found my problem but it's the X-ray tube so guess I wouldn't see it.
Old 04-04-2018, 08:27 AM
HV rectifier tubes rarely glow or just have a slight glow. It
dont take much heat to get the electron to make the jump
at HV. Best quick test is:
Unplug the top cap & let it hang away from metal.
Take a GOOD well insulated screwdriver & get it near the metal
of the cap. You should get a healthy apx 1/2 inch arc.
If not its the horz osc, output or damper IF its a tube.
Old 04-04-2018, 12:02 PM
benman94's Avatar
benman94 benman94 is offline
Resident Lunatic
If a 1B3 is gassy, it will often light up a bright pink, sometimes violet, depending on the identity of the intruding gas.
