Old 04-19-2018, 01:18 AM
grossbard grossbard is offline
Toshiba 27AF44 - Jitter/Interference
Hello,
I picked up a used Toshiba 27af44 from craigslist and I noticed that it has this "jitter" interference on the screen. It happens on all inputs and I tried an SNES and a PS2 and they both showed the same type of jitter. What could be the cause of this? Here are a few videos of the problem. It was kinda hard to capture with my phone camera but hopefully it will give you some idea of what the issue is.
thanks.
https://drive.google.com/open?id=1Rt...VngN1PzEyVjYKa
https://drive.google.com/open?id=1s_...iGyV8cC3AFByWv
Old 04-19-2018, 06:44 AM
Most likely the power supply isnt regulating its pretty subtle
so wont be easy to find. A photo of the back or the chassis
would help as Toshiba went from building there own to having
Orion A.K.A. Emerson build them. Also if it has a chassis number
post that, format is TAC-####
Good Luck
Old 04-19-2018, 08:56 AM
Zenith26kc20's Avatar
That model has a number of small capacitors in the power supply. I've seen a lot of strange problems when one or more open.
Old 04-19-2018, 10:15 AM
Here is a picture of the back:
I had a feeling it might be capacitor related. Do you guys thinking recapping will fix it? I'd like to keep this TV, it'd be great for my retrogaming setup. Other than a slight tilt, it has the best geometry I've seen from a consumer level flat CRT, and I've had a few in my time...
Old 04-19-2018, 10:43 AM
Good Luck
I have an Emerson that was made by Funai, a 20" around the same age.
I have an older Toshiba 19" table model ca 1990, assembled in USA that has an RCA CRT and a Gold Star chassis.
