Old 05-15-2018, 12:25 AM
TUD1's Avatar
TUD1 TUD1 is offline
Kig's TV Service
Zenith 25DC56 lost audio
This is the Chromacolor that I got at an estate sale in April of 2016. I had it repaired in May of that year, and it has been working perfectly since then. Just yesterday, for no reason, I turned the set on to watch The Simpsons, and the audio was almost totally quiet. I found that if I turned the volume control up rapidly, I could get some weak, scratchy audio for a second or two, then it would fade away. I tried that again tonight, but there was even less audio, if any at all. I checked the obvious first, checking the speaker connections, then I tapped around on the audio module that sticks up and was able to get some loud humming when I tapped certain places with my screwdriver. I then tried moving the IC to reseat it in the sockets, and that didn't do any good either. I have another set with this chassis I could pull the IC out of, but it's inaccessible at the moment.
Old 05-15-2018, 07:03 AM
Most common on these & hybrids was the output transistor.
Usually would make popping noises first. Can use 2 different
pks's that are interchangeable. OEM's were a kit that also had a VDR
for improved reliability. IC's also went sometimes 221-45 ?? easier
to change too. IIRC gotta go under for output.
Old 05-15-2018, 10:16 AM
Later today I'll try to snap a pic of the audio section of the schematic. Voltage measurements should be telling.
Old 05-15-2018, 11:35 AM
Yuppers. On all makes and models that used the high voltage type transistor. Used to know the Sylvania and RCA numbers by heart, but can't recall them now. Been a lotta years.
Old 05-15-2018, 02:43 PM
ECG124 or ECG157 IIRC.
Boy is it getting hard to remember.
Old 05-15-2018, 06:43 PM
TUD1's Avatar
Kig's TV Service
Yes! That was one thing I had to deal with on this set. It was like it was an extremely dirty control. It actually got better before it broke, to the point where the popping went completely away.
Old 05-15-2018, 09:41 PM
ECG124 sure rings a bell. Also RCA's SK3021.
Old 05-16-2018, 12:46 AM
Here is the audio portion of the schematic. The output came out a bit blurry...I'll retake those tomorrow if you want.
Old 05-16-2018, 01:44 AM
TUD1's Avatar
Kig's TV Service
How did YOU end up with a schematic for MY television??? These are the questions we should be asking.
Old 05-16-2018, 10:23 AM
IIRC my Avanti is also a 25DC56...Also as a Zenith person when the chance to own two books, one containing all their color schematics from the first through the end of the upright modular era, the other containing some of their full manuals for some color TV chassis I could not resist. I cannot pass up the chance to obtain service literature when available and in my budget.
Old 05-16-2018, 12:55 PM
TUD1's Avatar
Kig's TV Service
Unfortunately, this set will have to be placed on the back burner. My CTC-28 died last night for absolutely no reason, and that's what I'm going to have to worry about for the time being.
Old 06-11-2018, 05:00 PM
TUD1's Avatar
Kig's TV Service
Finally fixed the audio on this TV. I took the IC out of my other 25DC56 set and put it in this one, and that fixed it.
