Old 08-05-2018, 09:39 PM
Sealtest Sealtest is offline
Another craigslist project.. A sears console with no raster.
The other day I got a call from an older man who needed a tv removed from his basement. He said it was a Sears console and that it worked, or at least he thought it worked.
When I arrived I scooted the set away from the wall and saw screws missing and sticking out of the back, so yeah something wasn't right. We fired it up and it had no raster. It appears you can see some static but the screen is too dark to tell. I loaded this set into my station wagon and took it home since there is no reason to refuse a free set. For the last few hours it has been sitting running. The condition hasn't changed since letting it sit so I don't think the CRT is bad in it. Out of 4 CRT testers only one I have can fit the picture tube, but it is missing the attachment, so the condition of the tube is unknown.
Mostly I am wondering if I should mess with it without knowing the condition of the tube. The CRT does give off a good flash when powering the set off which is not something I've seen in a bad tube.
Old 08-05-2018, 10:49 PM
Jon A.'s Avatar
Jon A. Jon A. is offline
Don't mess with Esther.
I'd like to see photos of this set. I got two Sears consoles recently, I just haven't gotten around to a photoshoot for either. One is a JVC-made unit from 1984, the other was made by RCA in 1986 I believe and probably uses a CTC136 chassis, I haven't checked. That being said the pros here would appreciate having a chassis number to help you get started on this rig.
Old 08-06-2018, 06:14 PM
Here are some pictures of this set. I am not sure which number is the chassis number on this one. There is what appears to be the right number on the neck board but the lettering is faded out.
Overall it is a very nice set. Usually Sears sets are labled with the actual maker inside, but this one has everything labled as Sears. The last two Sears sets that came in for repair were made by Toshiba, but this one looks a bit different.
Old 08-06-2018, 07:17 PM
mrjukebox160 mrjukebox160 is offline
Looks like a Sanyo.
Old 08-06-2018, 09:07 PM
Originally Posted by mrjukebox160 View Post
Looks like a Sanyo.
564 is the Sears source number for Sanyo.
Old 08-07-2018, 01:37 PM
That's pretty cool. I haven't had a Sanyo before.
How good is Sanyo compared to other well known brands?
I have a big book of case histories on TVs that I have been looking at. It seems that all similar problems differ in the fact that messing with the controls changed the screen. One of those cases had a bad resistor on the neck board. Anyways Friday I'm going to drive an hour and a half to borrow the adapter for the CRT tester. That'll get rid of a lot of guessing.
Old 08-07-2018, 02:20 PM
Yup a Sanyo. These usually had Sylvania CRT's EIA 312
VERY good sets as a rule.
If it uses any IC sockets watch for very int problems.
Sounds like you have HV but no raster. Look first
at the G-2 on the FBT then resistors on the CRT brd in the G-2
if any.
BTW the big white tag with the long number starting
564. ####### is the real model. 4 digit sears numbers
are near useless.
Old 08-07-2018, 03:01 PM
Jon A.'s Avatar
Nice, clean cabinet design on that one. Assuming that Sears stopped carrying Sanyo-built sets as soon as they started with RCA, yours may be one of the last Sanyo-supplied units. The back cover of my RCA/Sears is stamped 9-86 in a couple of places; I assume that's the manufacturing date.
Old 08-07-2018, 07:49 PM
The last RCA supplied Sears set I worked on had the CTC177?, the one with the on-board tuner problem.
A Sears set, slated for the scrap-heap is a rebadged Gold Star, source 580. Also, Funai supplied the small TV/VCR combos.
Old 08-07-2018, 10:09 PM
This set was built in May 1986, so it really does seem to be right at the end of Sears' usage of Sanyo.
I checked and resoldered all of the components on the CRT board with no luck. I can still see some very dark raster but it looks like the lum section has a cold joint. Next step is to discharge the set and fix all the joints in that particular section. There is an IC in that area so the hope is that the joints for it are cold. Every now and then a Zenith system 3 or CCII comes in with no raster and resoldering that white resistor pack always fixes it, so maybe the IC chip in this set will have the same issue.
Hopefully this set will live. It'll make a nice addition to the ever growing stack of working sets in my basement (no one wants TVs around here so we make walls out of them for fun).
Old 08-08-2018, 09:44 AM
Sears started labeling Sanyo's as LXI about the time of the
switch to "Brand Central" when they started selling brand named
sets. Sears bought most sets without a factory warranty so
only they could do the warranty. This was never told & pissed a
lot of people off when something broke a few days out & would do zero
for you. Mom & Pops would stretch things & so would the factory
if it were from an independent.
Old 08-09-2018, 12:19 AM
So Sears stopped selling "Sears" TVs and just sold name brands without any rebadging? Actually growing up I don't recall ever seeing store brand TVs like JCP or Sears unless they were pretty old, but by the time I came around CRT TVs were on the way out. When did stores in general stop selling sets with their name on them?
Also If all goes well I will hopefully have the CRT tester attatchment for this set Friday, or if my buddy lets me I'll just bring the whole set to his house and test it in my station wagon. If the CRT is bad I don't know what to do with this set. I don't want to take it to the scrap yard but my family hates all the old sets hidden around the house.. Also why I bug so many people on here with repair questions
Old 08-09-2018, 10:12 AM
I had a Funai sourced Zenith 13" TV-VCR combo. The Zenith model number was pre-fixed by the letters SR.
They were always intent on selling the customer a maintenance agreement.
Old 08-09-2018, 10:19 AM
The forum members and myself never thought that you were that young.
I started very young as well. 60+ years ago.
If the CRT is good, maybe your buddy will take it in.
Old 08-09-2018, 01:16 PM
House brands like Insignia still exist. Sears from the daays of crank gramophones to some time in the 60's or 70's used the Silvertone badge for gear made by a wide variety of makers. The Sears badging appeared later.
