Old 08-08-2018, 11:14 PM
Predicta Debutante Restoration
I got this TV last fall and now that other people's projects are nearly all done, I'm starting on my own project. I messed with this TV just a little in February. Then the other people's projects for the nearly the last 5 months.
On with the show!
Here is the TV as I got it. The 17" CRT tested very good!
The chassis number is a 11L43.
Here is what the chassis looked like after I pulled it from the cabinet:
And a few pictures after going to the car wash.
Old 08-08-2018, 11:25 PM
I decided to make up all new networks like I did on my Seventeener II project.
I used my CAD program DeltaCad. I used the Seventeener II drawings a "seed" to come up with the ones I needed for this project.
I etched my boards, then populated them. Then they were coated with 15 minute epoxy on both sides.
Once cured, they were spray painted to approximate the original colors.
Old 08-08-2018, 11:42 PM
I decided not to re-stuff the electrolytic caps. Instead I used the method that Bob Andersen describes in his videos on his restoration of a Princess/Debutante. I still have to pull the main board, and when I do, I'll place the 3 electrolytic's from the small E-Cap.
First up were the 2 200uf 160V caps. I used some 220uf 250V 105 degrees Nichicon caps. They were placed on the terminal strip that is next to the Fusistor. One was a direct replacement on the terminal strip while the other came "from" the large 4 section E-Cap. While I was messing around with the terminal strip I replaced the 2 original diodes with 2 1N5408 diodes.
The other 3 that came "from" the large E-Cap was attached to the terminal strip located between the main board and the IF board.
I then removed several wires that were not needed and the "jumpered" the wires where they would have connected to each E-Cap terminal.
Old 08-09-2018, 07:10 AM
decojoe67's Avatar
Nice work so far. You have the motel version ID'd by the white cabinet, antenna delete, and instruction sticker. I have the regular brownish-grey consumer version. That model has always been my favorite Predicta because it's the last model offered in '59, and the cleanest design of them all. I love the expanse of glitter-woven cloth on the front too. Very "mid-century" looking.
Good luck with the resto!
Old 08-09-2018, 11:24 AM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Top notch work on those PEC networks!
How did you clean the chassis/PC boards?
Old 08-09-2018, 12:43 PM
he took it to the car wash.
Old 08-09-2018, 12:46 PM
DavGoodlin's Avatar
Motorola Minion
Awesome work! I never knew there was a 1961 Predicta and that chassis is nearly identical to a Philco 23" console I have. That "cool chassis" design sure beat the hell out of the earlier "warm chassis" Predictas
-Dave G
Old 08-09-2018, 04:25 PM
decojoe67's Avatar
I've been researching vintage TV's for many years and have never seen any period literature proving a Predicta was for sale to the public after 1959. The '58's were the 21 inchers, and the '59's were 17, with the Debutante being in the final run in '59 and the cheapest model.
Old 08-09-2018, 05:12 PM
Wasn't the Continental (AKA danish modern) model introduced in 1960 ? It used essentially the same chassis as the 17" models but with a better 21" CRT than the original 1958 models.
Old 08-09-2018, 05:36 PM
I then did the IF board. It was simple to remove. After a good cleaning, all the resistors were replaced with 1W. I then added solder to each ground stud to beef them up. I also checked each coil. All was good.
After the board was installed, I wrapped each wire around its stud 1 or 2 turns. Then cut off the excess wire leaving a small 3/32 end sticking out. This is to aid in removing the wire in the future. Then each one was soldered.
Old 08-09-2018, 05:38 PM
decojoe67's Avatar
I've always heard that Bob, but I've never seen any ads or articles for Predicta's past 1959. I'd have to see one to believe it. It's common knowledge that the Predicta got a bad rap in '58, then tried to improve the set in '59, but the damage was done. It would be hard to understand how Philco would've kept the line going for 2 more years (it's often mentioned the end was '61). Like with this Debutante, they had to sell them off to motel chains to get rid of them in '59!
Old 08-10-2018, 05:17 PM
Today I worked on getting the main board removed. I labeled each wire with the "L" designation and then unwound the wire wrap. Then unsoldered the ground links. Once removed I cleaned up the excess solder on the ground studs and cleaned off the board real good.
On to recapping.
Old 08-10-2018, 08:12 PM
irext's Avatar
irext irext is offline
The car wash approach scares me a bit. How do you ensure that no moisture remains in IF coils etc. Having said that it certainly does the job. I'll be watching your progress with great interest.
Old 08-10-2018, 08:29 PM
Ain't done the car wash bit, but I do go after really dirty chassis (like mouse house sets) with the garden hose in 'jet' mode...Don't overdo spraying on anything delicate like labels, and let it dry for 2 days to a week before applying power again depending on temp and humidity. If it is summer and there is a good sunny day letting them dry in the sun can help speed the process.
Old 08-10-2018, 08:33 PM
I bake it in the oven at the lowest temperature for about an hour.
The car wash gets the initial cleaning done. For the "final" cleaning as to what you see here, this is what I do.
After the board was removed from the chassis, a good look see inspection was done to determine the condition of the board. Both boards were in great shape. Then I head over to the sink and turn on lukewarm water. Then I spray the board with "Scrubbing Bubbles" bathroom cleaner. I let it foam for a few seconds, then I use a 1" chip brush I get from Harbor Freight, to gently, but completely, brush the entire board. Getting in between the components. You'll be amazed at how brown the foam will get. Probably from smoking all those years. Then it is completely rinsed off and the process is repeated. Once rinsed off, I shoot contact cleaner into the pots, tube sockets, adjustable coils, and elsewhere I think it needs it. Then into the oven again for about an hour or out in the Texas hot sun.
