Old 08-28-2018, 05:51 PM
flyrihght flyrihght is offline
Magnavox T989 chassis flyback
I am in search of magnavox flyback #361499. t989 chassis r313 1200 ohm resister opened. replaced with tripler disconnected and no hv. seems like there is drive. be glad to pay shipping on a whole chassis. i may have to get back in there and troubleshoot that d board. any tips?
Old 08-29-2018, 11:31 AM
Some of these FBT's plugged in. The connections would toast up.
Also the mother board & module connectors went cold a lot. Dont
forget the frame grounds....
It doesnt show one but this is about the time they switched to
4-lead caps. An open leg will kill the HV.
The SCR is for HVSD. Pull it to eliminate BUT use a variac, you may
have too much HV. Start it at abt 70VAC.
With the tripler input unhooked you should get a healthy 1/2" arc
at the FBT out. These were not FBT eaters. Only ones I changed
were badly burned from the bad connections.
Old 08-30-2018, 09:39 PM
thank you
I will check these suggestions and let you know results
Old 08-31-2018, 09:48 PM
I checked the Thordarson number, looks like their part # FLY-462. I didn't see on in my stash.
