Old 12-29-2018, 01:55 PM
ZenithNut ZenithNut is offline
Curtis Mathes Color Roundie ID
Hello,
Last night I dragged home a CM roundie. Theres not a lot to go on with it. Most the tubes are CM branded with date codes of XX-65. Has a RCA Hi lite 21FBP22A crt in it. Theres a chassis # of C20-1j i think it is. I will try to upload photos here. I may have to resize them. Maybe a CTC-15 clone?
Old 12-29-2018, 01:58 PM
Photos
Old 12-29-2018, 02:17 PM
Front. A bunch of the controls like tone are sorta hidden under the bottom 3 controls
Old 12-29-2018, 02:43 PM
Tony V's Avatar
Tony V Tony V is offline
It's definitely a RCA clone. The type Horizontal, damper and vertical output tube will determine whether its a CTC12, 15, or 16 chassis clone. I'm leaning towards it being a CTC15.
Old 12-29-2018, 03:02 PM
Tony the damper is a 6dw4. Hor and vertical are 6fq7 and 6gf7. 1av2 focus rect. Should I try to get the sams for a ctc 15/etc or for this set specifically?
Also the diode bridge is mounted on terminal strips under the chassis, not on the pcb.
I downloaded the sams for rca ctc 15 off the early television museum. Looks really similar except the CM uses a tube focus rect and the rca ctc 15 uses a diode.
Old 12-29-2018, 03:49 PM
Steve D.'s Avatar
Steve D. Steve D. is offline
Zenith nut, You are correct about the diode in the RCA. Here is the RCA CTC-16 tube listing which is similar to your CM model.
Old 12-29-2018, 04:05 PM
I think I have a lead on the sams for this CM. Sams 831-2 but im not gonna fork up $22 bucks until I know thats what is.
Steve D.'s Avatar
Zenith nut, This page on CM CTC-15 clones may also be of interest to you:
Old 12-29-2018, 04:12 PM
Thats it. A CMC 20. Sams 831-2. Thanks!
Old 12-29-2018, 04:18 PM
Steve, the hor osc coil broke. Can the little red wire be soldered together and repaired? It broke at the base. The core is intact. I have a soldering station with a thermostat for the iron.
Old 12-29-2018, 04:20 PM
Steve D.'s Avatar
Zenith nut, Not to overstay my welcome, but here is the tube layout for the CM CMC-20 chassis.
Old 12-29-2018, 04:29 PM
No stay as much as you can! Just looked at whats left of the tube chart on the hv cage and it calls for a 1v2 focus rectifier not a 2av2 listed in the cmc20
Rca ctc 16 uses a 1v2
Old 12-29-2018, 04:57 PM
Steve D.'s Avatar
I noticed the CTC-16 as I posted. And the different focus tubes as well. Perhaps a production change on the layout chart. The tube complement list also has the 2av2 listed. Checked my RCA reference book and the 1V2 & the 2av2 are not listed as interchangeable. I have no experience w/these "later" model roundies. I would suggest that you repost or re-ask your questions to VK. Plenty of folks w/CTC-15's and if you're lucky a CM clone.
Best in the new year,
-Steve D.
Old 12-29-2018, 07:04 PM
-Steve D.
Where in videokarma should I repost this?
Old 12-29-2018, 11:20 PM
Steve D.'s Avatar
Hey Alex, I just now returned to my computer. I suggested VK color tv section as you did before. However, you did fine logging on to The Vintage TV Collectors site as well. I read your inquiry about the blue lateral magnet. You received the proper response. Hopefully you'll find the original or a good replacement. I also hope you received a reply on the hor osc coil. I'll look forward to viewing your progress on the CM.
Best,
Steve Dichter
[email protected]
