Old 01-27-2019, 10:31 PM
Zsuttle's Avatar
Zsuttle Zsuttle is offline
Zenith 10S669
I just finished recapping this set, and redoing the wiring. Boy does this set use that old rubber wire. Anyways, to use the station push buttons, does the band selector have to be set to the "automatic" position? Also, should the inductor/resistor on the plate of the 7G7 be tested? If so, how should I do that? I'm not getting a signal through yet, though I've confirmed that the audio stage is working up to the back of the 2nd IF transformer.
Cheers,
Zach
"If it isn't broke, you aren't trying hard enough"
