Philco 624
Grabbed this guy off CL for a tenner
![]() It's a farm set, so I gotta find a golf cart battery. ![]() I'm planning on going through the electronics soon but the cabinet resto/refinish will have to wait for spring. The cabinet looks shabby, but that's mostly the finish. there's a few chips/de-laminated areas, but with some carefully cut/matched chunks of walnut veneer, I should have her lookin good |
I also see it has a 3 volt bias cell. I would use a couple carbon-zinc penlite cells. The "C" drain is so low, it's basically shelf-life. The tubes are filamentary tubes so the have to be a DC source.
Vibrator hums okay on a little 6 volt battery, either way I'm going to be retrofitting one of these https://www.pekorf.com/RadioHomePage.html and saving the mechanical one for an EMP
![]() Thanks for the tip on the bias cells I also have a synchronous Mallory Vibrapack and a dual power Navy Morale radio (async. vibrator w/ gas rectifier) around here that I've been playing with, so I'm no stranger to vibrating power supplies. I just got done identifying all the capacitors and gouging out the bakelite blocks (3 total) so I can put together a BOM for the recap. |
Youtube has a repair series on this radio. JIC
Rick (Sparks) Ethridge |
Those are quite useful. I stayed up wayyy too late watching those
![]() I have most of the capacitors marked, I tested all the resistors, marked the outta spec ones (even out of 20% tolerance!) replacement capacitors ordered. I still gotta mark the picofarad value caps, schematic says their mica, their appearance says they're moulded paper "mica bombs" |
| Audiokarma |
This is a nice radio once you get it working. An rf amp tube makes it special. A good antenna and this radio will surprise you! A really good DX queen.
This model lacks the RF amp stage unfortunately, It's the '36 model 624, not the very similar 37-624.
She lives!
I had a resistor hooked up wrong that was causing it to just play a loud hum(and the resistor getting really hot), I ended up replacing most of the original resistors trying to get it to play (all the voltages were way off anyway, and I had some filaments not lighting) Now I just have vibrator hash to quiet and yes I scored a golf cart battery |
Very, very nice. Good show! Another one lives again. I should live so long.
| Audiokarma |
