Go Back   Videokarma.org TV - Video - Vintage Television & Radio Forums > International Vintage Televisions
Old 03-04-2019, 04:58 PM
Komet's Avatar
Komet Komet is offline
Philips X25K121
After 10 years I put my hands on this beast: it was the first color TV sold in Europe in 1966-67. It's a full tube set and today is extremely rare, especially in full working conditions.
The first Philips colour TVs from a 1967 leaflet: rear left the 21KX100A used for the experimental NTSC and PAL transmissions, rear right the model with the K5 chassis with an improved electronic design and the X25K121, the first commercial set.
https://i.imgur.com/7ikVE6Q.jpg
This is a Philips X25K121, the first commercial color TV sold by Philips in 1966-67 and overall the first TVC model sold in EU. From the top the commands are for:
- Volume
- Brightness
- 6 preselected channels
- Color on/off switch
- Power switch
- Contrast
- Color saturation
https://i.imgur.com/VQgq1xb.jpg
The Philips K6 full tube chassis
https://i.imgur.com/afVxZ9C.jpg
Audio and color processing circuits. The data on the PAL delay line says that this set was built in 1968
https://i.imgur.com/599dvfH.jpg
Vertical and line oscillators + vertical output circuits
https://i.imgur.com/ic4pSTp.jpg
High voltage cage with the line output transformer. Tubes: GY501 high voltage rectifier, PD500 high voltage stabilizer
https://i.imgur.com/yEp5Ct4.jpg
Tubes and transistors layout
https://i.imgur.com/ZLHGxKw.jpg
The line output/high voltage section
PL505 main line output
PL500 auxiliary line output
PY500 damper
DY51 focus rectifier
Video of the TV
https://www.youtube.com/watch?v=wd5kTJftuSE
Facebook profile
Old 03-04-2019, 06:09 PM
Nice set!
Good to see you back Komet.
I'm actually employed by Philips presently...If that continues for a decade I might have to find and import one of those roundys in the background.
Old 03-05-2019, 08:53 AM
AlanInSitges's Avatar
...and every one of those caps is probably still good!
Old 03-05-2019, 02:13 PM
Komet's Avatar
Nice set!
Thanks! I have find a lot of nice vintage sets, I will show them in the future
That roundies... The 21KX100A with the experimental K4 chassis was a small production, about 150 sets. It uses a sub chassis for power supply and deflections and another one for the signals, the color demodulation was on a printed board probably for being easy to replace. About 10/15 sets are known today.
The other one, with the K5 chassis was only a prototype, nobody know its fate.
Yes! Probably I will replace only the booster capacitor for safety reasons.
Facebook profile
Old 03-08-2019, 06:40 AM
BRC2000 BRC2000 is offline
Hi All
If you go to this web site :- http://www.vintage-radio.net/forum/s...d.php?t=152009 you can see the Philips 21KX102A – The British version of the original Philips 21KX100A working.
Keith
Old 07-27-2020, 07:23 PM
stragulus stragulus is offline
*Finally* I found the first color tv I ever owned as a teenager. I bought it for the symbolic price of 1 Dutch guilder at a flea market. It must have been about 20 years old by then and it did fully function, but the colors were extremely dull. After a few years of enduring that I attempted to 'repair' it with a super strong magnet that magnetized the shadow mask and well, the problem with the dull colors was gone..
Ended up tossing it into the local waste recycling trash heap, still feel bad about it!
Old 08-02-2020, 01:56 PM
Telecolor 3007's Avatar
I love old stuff
Why did you dumped it?
Sailor Moon
