Old 03-29-2019, 05:40 PM
Li ion batterys
I don't really know where to post this question but I have a helicopter that had 3.7 volt 1500 mah lith ion batterys that went bad so I replaced them with the same only with 3000 mah the problem is it won't lift off so my question is that is there a discharge rate difference between the 2 different mah batterys. Does the 1500 deliver more amps then the 3000. I know the 3000 mah would give more lasting time but the discharge rate I don't know.
Old 03-29-2019, 05:59 PM
Weight difference?
Old 03-29-2019, 06:48 PM
kvflyer kvflyer is offline
Weight difference?
Have to ask the same question, weight?
Old 03-29-2019, 08:03 PM
Well I understand that there are also high drain batterys that are for helocopters. The ratings seem to go by 1 c up to10 c for high drain so maybe my batterys are not rated to put out the highest amperage, high drain plus the weight possibly.
Old 03-30-2019, 10:09 AM
Notimetolooz's Avatar
There is another forum on the web that can answer those kinds of questions better. RC Groups.
https://www.rcgroups.com/forums/index.php
Old 03-30-2019, 12:12 PM
Specifically, their 'Batteries and Chargers' and 'Electric Helis' subforums would probably be the best bet.
