Old 04-01-2019, 06:21 PM
Tellyrescue Tellyrescue is offline
CTC-9 focus pot help
What is the correct type of pot for the focus control?
The sams states 100K 2W wire wound part.
The set has a carbon pot installed in it and I'm not sure if it is factory or not.
The focus on my set is a little soft and a snapping sound is heard if you mess with the control.
The control tested good out of circuit.
Is the sams a mistake or do I need to track down a wire wound pot?
Old 04-01-2019, 06:31 PM
ohohyodafarted's Avatar
Bob Galanter
Seems to me that 100K would be rather high for a wirewound pot. I should think it would be carbon at that resistance. I dont have a RCA print for CTC9 so someone else with a RCA print will need to weigh in on what the actual spec is for that pot.
ME http://AntiqueTvGuy.com
Old 04-01-2019, 08:48 PM
I think that's another Sams Snafu!
100K WW pot? What kind of wire would the thing be wound with?
Old 04-02-2019, 09:35 AM
reeferman's Avatar
RCA field service guide shows 100K, RCA# 105808A (wattage not given).
Phil
Old 04-02-2019, 10:10 AM
It's not like the don't exist.
Digi-Key Part Number:534B1104JC-ND
I was able to find a 100K WW at 2w rather quickly
So, who knows. :p
but you are Prob right, and its carbon.
Old 04-02-2019, 10:33 AM
Remove it and take it apart. See if there's carbon tracking inside.
I looked up the schematics on the CTC7,9 and 10. The CTC7 shows a pot as well as the CTC9, the 10 and newer has a coil.
The CTC7 only shows an RCA part number.
Old 04-02-2019, 10:36 AM
So, who knows. :p
Why would you need a WW? No current, just a potential!
Old 04-02-2019, 10:52 AM
dtvmcdonald's Avatar
But look where it is. It's not getting a lot of power, but it is across part
of the flyback. Hence, its getting a big voltage pulse so one thing that matters
a lot is the peak voltage rating. Is the case grounded or carefully floated at over
a kV? The DC on it is the boost voltage.
Old 04-02-2019, 01:46 PM
more confusing
https://www.onlinecomponents.com/cor...-45184738.html
https://www.ebay.com/p/Mallory-Poten...MPK/1534170311
Part # M100MPK as shown on SAMS can still be found, (not cheap) and is ww
no hits on search for the RCA # 105208A though.
Old 04-02-2019, 02:18 PM
As a bit of confirmation, the SAMS for the ctc7 is close to the ctc9 also has the same POT, and is shown to be a wire wound, and even lists the SAME RCA part # 105208A , so chances are it SHOULD BE wire wound, as shown in the SAMS, but my guess is as good as anyone's :/
Old 04-04-2019, 10:44 AM
oldtvman's Avatar
oldtvman oldtvman is offline
Larry Melton (oldtvman)
Phil
The omnibus shows it as a 105208a, I'll look but I don't think I have any new ones left.
[IMG]
Old 04-04-2019, 11:04 AM
The one I found on EBAY seems new, but $40 seems rather inflated to me for the part
