Old 04-19-2019, 05:13 PM
liammc00's Avatar
liammc00 liammc00 is offline
real TVs have a CRT
Montgomery Ward 1987 13" color tv model JSJ12227 (bad horizontal )
¹I recently got this TV for $1 at antique store and it dose power up but has horizontal problem. I have checked the caps in horizontal drive circuit. Cap C507 is 47mfd at 35v tested at 8.08 ohms so it's bad and cap C506 tested with litter higher then it should the rest were in spec. The picture below will show you the symptom I'm have with this TV. Other then horizontal it seems to work fine. I have to order some caps before I can continue with the repair on this TV. the tv seems to be a low hour set.
