Old 04-22-2019, 09:36 AM
Telecolor 3007's Avatar
I love old stuff
In the past days the audio of the car stoped when you turn on off the engine?
One of the most anyoing things in automobiles is that the audio system of the automobile is turned off for a few seconds when the engine is started or turn off.
In the past it was the same or it's just a more recent ideea?
Sailor Moon
Old 04-22-2019, 09:50 AM
dewickt's Avatar
dewickt dewickt is offline
Will fix about Anything
In the days of tube radios you wanted the radio off when the engine was off, after all a 6V tube radio drew 10+ amps and could kill a tired battery in no time.
Terry WB4NHB
DeWick Repairs (retired)
www.mcintoshaudio.com
Old 04-22-2019, 10:00 AM
I don't think I've been in a car that runs the radio when cranking the engine with the starter motor...
GM cars 2002 and newer will leave the radio on after you stop the engine and remove the key until you either open the door or a something like 10 min timer runs out.
Old 04-22-2019, 10:05 AM
I love old stuff
I was talking about switching off for a few second. Let's say that you stop the engine. You turn off the ingnition and the radio stops. After the engine stoped, the radio (or whatever audio is) will turn agian. On older cars it was this stupid few second stop when turning on or off the egine?
Sailor Moon
Old 04-22-2019, 10:06 AM
I love old stuff
Know that.
But pre fuel injection cars could be crancked shaft (at least the gasoline/petrol ones)
Those old radios got... vibrators
Sailor Moon
Old 04-22-2019, 10:53 AM
As I said on the 02 GM cars I've had you can go from a running engine to engine off key removed from the ignition and the radio won't stop for a second... you have to open the door or wait a good 10 minutes for it to turn off.
Old 04-22-2019, 04:31 PM
compu_85's Avatar
compu_85 compu_85 is offline
Procrastination Expert
Ya... GM calls it retained accessory power
On many cars "accessory" loads like headlights, cabin blower, and radio get turned off when the ignition is turned to start, to give maximum cranking amps.
On my 91 Mercedes the radio keeps itself on for 3 seconds after the ignition is off... to give you time to go from RUN to OFF to Accessory without interrupting the tunes.
On my 14 Cadillac ELR, the audio system originally played a startup / shutdown sound. I turned that off first thing... quite annoying. When turning the car off it would stop the music playing, do the sound, then resume the music.
-J
Old 06-11-2019, 09:01 PM
KentTeffeteller's Avatar
Gimpus Stereophilus!
Know that.
Not most cars in the USA, they had electric starters. Hand cranked, only on very antique cars in the USA.
Old 06-11-2019, 10:45 PM
Before the accessory power was controlled by computer, the radio was on the accessory terminal of the ignition switch. So, as soon as you turned the switch to OFF, the radio stopped completely. Was that your question?
Old 06-11-2019, 10:48 PM
Also, in the modern cars I have driven, the radio and other accessories do stop while cranking the engine, but not even momentarily when you shut it off, until you open the door.
Old 06-11-2019, 11:56 PM
I love old stuff
Yes, that was my question.
But if you wanted to keep it runing?
Sailor Moon
Old 06-11-2019, 11:58 PM
I love old stuff
I've seen cars with electric starters that could be cranckshaft.
Sailor Moon
Old 06-12-2019, 10:18 AM
Then you would not turn the switch all the way to OFF. The positions on the switch were OFF, ACCessory, RUN, START. A spring would return the key from START to RUN when you released the key.
On even earlier cars (like 1930s to early 1950s, I guess - before my time) the starter motor was activated with a foot switch.
Old 06-12-2019, 12:12 PM
I love old stuff
Well, "Renault" 12 a.k.a. "Dacia" 1300 (1310 was a little bit modified version) could be crankstarted, even it had ignition key. Even some early "Dacia" 1310 could be crankstarted. And we talk about post 1966 period...
Sailor Moon
