Old 04-29-2019, 01:27 AM
Outland Outland is offline
Slight Blue Tint with Color Down
I picked up a lightly used Panasonic set (CT-20S10S) with the same chassis as mine (CT-20S2S) as a potential replacement CRT. They are the same TVs, except the new one has composite input. They have the same remote and menus.
My old CRT is a little tired, with slight burn-in from closed captions and a slightly dim top right corner. With color all the way down, the image is black and white, maybe a very very slight green tint (maybe).
On this new one, there are no dim corners, no burn-in, and the image is significantly brighter and a little sharper.
However, with color all the way down, the new one has a slight blue tint. What is the reason for this? I can't imagine it's more worn than the old one, which doesn't have a tint with color down. Is this how the set was when new?
Old 04-29-2019, 09:28 AM
If you have darkening on one side, check the 4.7mfd 315 cap on the CRT board or nearby.
Old 04-29-2019, 01:04 PM
Slight tint of color with color control minimum probably just means it needs a slight color tracking adjustment.
Old 04-29-2019, 07:44 PM
Even on a 1994 TV? That would probably be in the service menu.
Old 04-29-2019, 09:35 PM
Ooops - mixed up my threads - sorry
Old 08-18-2019, 10:06 PM
So how do I adjust the color tracking? Watching a black and white movie reveals the slight blue tint as well.
Old 08-18-2019, 10:15 PM
Sorry, maybe someone else here knows how to find the service info or access the service menu if that's what it takes.
Old 08-18-2019, 10:45 PM
Here is what the service manual says.
This is a little overwhelming. Which of these settings controls tint (regular menu tint has no effect)? How do I jump FA1 and FA2?
Old 08-18-2019, 10:51 PM
You do not want any of the DAC (B) mode adjustments. You want the CRT (C) mode adjustments. Do you have a page showing them and telling their names?
Do you have a diagram showing the location of FA1 and FA2? Are they close enough to bridge with a screwdriver, or do you need a wire/jumper wire with alligator clips?
Old 08-18-2019, 10:59 PM
Yes, here is the location of FA1 (N/2) and FA2 (N/3). Looks like they are down by the tuner. I will take off the back, jump them with alligator clips, then turn the set on and follow the directions to enter serviceman mode.
Are you referring to this table?
Thank you for the help. I want to carefully do this adjustment because I like the TV.
Old 08-18-2019, 11:07 PM
Yes, that table. Follow the instructions for C1 through C5 to get rid of any tint to the monochrome picture.
Old 08-18-2019, 11:12 PM
Will do. Thanks so much.
Old 08-18-2019, 11:36 PM
Is there a good test pattern to use for color tracking adjustment? I have a video essentials DVD somewhere.
Old 08-18-2019, 11:55 PM
A gray scale (steps) is best; color bars with the color turned all the way down works too, or you can even do it with regular programming with the color turned all the way down. (I don't know if your set automatically turns the color down when you are in CRT adjustment mode, but that would make sense.)
As the instructions state, go for a gray picture with no noticeable tint.
Old 08-19-2019, 12:00 AM
Off to bed now - good luck
