Old 05-25-2019, 09:58 AM
Tony F Tony F is offline
1949 Admiral 20A1 chassis question
I have 2 identical 25 Hz chassis, one has this modification the other does not. It looks as if it is a factory addition. This is in the later serial number set. There are 2 ceramic caps (both 120 pf) tied in series for a total of 60 pf which is wired in parallel across R89 the 7500 ohm 25 watt power resistor that connects the cathode to the plate of the 6W4 half wave damper tube V18. The caps look like brown, red, brown, white color code. Could someone explain why this mod was done ? I don't see anything under production changes.
Page 4 of the pdf has the schematic
https://www.earlytelevision.org/pdf/...a1_sams_77.pdf
Thanks
Tony
Old 05-25-2019, 11:08 AM
Likely it's to increase width beyond what the 'width' control is able to provide.
Old 05-25-2019, 11:36 AM
Interesting. Thank-you for the explanation. I learned something new today.
Tony
Old 05-25-2019, 12:03 PM
Here's a recent related discussion - http://www.videokarma.org/showthread.php?t=271637
Old 05-26-2019, 10:46 AM
Tim Tress Tim Tress is offline
In Admiral sets of that era, it's not uncommon to see resistors or capacitors in series or parallel, in order to get the required value. Sometimes, they even used prewar components; evidently, they were hit with parts shortages during 1949-52.
Old 05-26-2019, 02:43 PM
kvflyer kvflyer is offline
Exactly. Many of my Admiral TVs, radio have parallel/series resistors. My understanding is that the Korean Conflict caused many shortages in the component supply. Originally, I thought it was some kluged together repair. But alas, not the case...
