Old 06-10-2019, 04:20 PM
Odd crt
There is a crt on eBay that is from the 1930 s and the pinout is listed but why is there only 2 separate deflection plates but the other 2 seem to be tied to the 2nd anode at least that's what the pinout shows and it only has 8 pins on the end cap so it can't be used for an oscilloscope clock, I would need 10 for it to work.
Old 06-10-2019, 06:24 PM
WISCOJIM WISCOJIM is offline
Link?
Old 06-10-2019, 06:46 PM
Originally Posted by WISCOJIM View Post
Link?
eBay under crt tube 1930s clear glass tube
Old 06-10-2019, 06:49 PM
Thanks.
https://www.ebay.com/itm/Mid-1930s-D...frcectupt=true
Old 06-11-2019, 09:02 AM
Yes, some early electrostatic CRTs had two deflection plates tied together. You AC couple a signal to the other plate to move the beam back and forth.
Old 06-11-2019, 12:42 PM
So I guess it's out of the question for a scope clock of even tv use. Being both of which need separate plates.
Old 06-17-2019, 08:24 PM
Tom Albrecht's Avatar
One could still make this work. The main thing you need is a potential difference between plates to get deflection (to generate electric field). For each pair, it's OK if one of the two plates is held at a constant potential and the other one is moved relative to it.
This does, however, require twice the voltage swing on that one plate compared to driving opposite plates with opposite waveforms.
