Old 06-29-2019, 08:44 AM
iong iong is offline
Flyback Screen Control
Was does the flyback screen control on solid state color tv effect. I'm not sure how to adjust it.
Thank you,
Perry
Brooklyn
Old 06-29-2019, 08:50 AM
Set it so you dont see thin white lines & can turn the brightness
all the way down. Some sets will shut down if it goes too high.
If that happens just back off & restart.
Old 07-08-2019, 09:07 PM
Popester's Avatar
Popester Popester is offline
Flyback screen control. Not sure what you mean. But the screen control you normally set your brightness with an ota (off the air) image or dot bar generator on grey setting and contrast to its highest and use the three colored screen controls to a grey looking image then turn down the contrast and brightness to minimum and whatever dominant color that doesn't look grey you compensate with the background controls. That's kind of an abbreviation of the process.
My wish list:
Sony KV-7010U
Sony KV-1220U
