Old 11-09-2019, 01:37 PM
mepurina mepurina is offline
Admirial 30A1 white vertical stripe
Hi All: I just recapped a 1948 Admiral 30A1. After fixing all the typical issues like the horizontal linearity and centering there is one problem I have not figured out.
I get this wide vertical white bar down the left side of the screen with retrace lines in it. Is this a sweep issue or a video issue? Any info would help. I am sure this has come up before as a common problem with this old set. Any help would be appreciated.
Old 11-09-2019, 04:18 PM
Kevin Kuehn's Avatar
Workin' Late Again
Likely some variation of horizontal foldover. First try a different damper tube. Sometimes horizontal drive setting can affect it. The vertical retrace lines are probably a separate issue. I don't think those early Admirals had vertical retrace blanking, and so with high brightness and contrast settings that's a fairly normal thing. Oh and welcome to the forum.
Old 11-09-2019, 04:47 PM
With a picture on screen, turn the horz.hold control both directions (but not so far it loses sync). Does the white bar change/move/shift at all?
Old 11-09-2019, 05:35 PM
Workin' Late Again
Hmm. In the second picture we're seeing the horizontal blanking bar on the right-hand side, which could indicate the whole picture is being scanned but not in perfect sync with the TV's horizontal frequency. That being the case, if he moves the picture to the right with the horizontal control, we may not see any horizontal blanking on the left-hand side? I guess in theory the horizontal blanking bar should be equal width on both right and left sides if the horizontal oscillator is in perfect sync with that of the signal it's receiving?
Old 11-10-2019, 01:14 AM
The horizontal AFC detector (and or hold pot setting) can be off far enough to sync such that active video is present in the retrace creating a foldover look...A worthwhile problem to rule out early.
Old 11-10-2019, 06:57 AM
Check the big power resistor inside the HV cage. They are often bad
Old 11-10-2019, 11:29 AM
Workin' Late Again
Agree. The problem is AFC can be so effective that one can't get the horizontal hold control to shift the picture enough without disabling it. I have my Emerson 698 on the bench, which when wave shape is adjusted correctly, the hold will only budge the picture about an 1/8" in either direction, which is the goal with AFC. The Admiral 30A1 AFC may not be so aggressive.
Old 11-11-2019, 07:18 AM
Thank you all for your input on this strange problem.
I did some experimenting and testing on this problem and this is what I found....
The Damper tube tested good.
The white bar does not shift at all when turning the Horz hold.
The power resistor was bad and had been replaced.
I grounded the video signal at the video amp to eliminate a picture on the screen but kept the sweep circuits working , and the white bar is goes away.
This lead me to believe the problem causing the white bar is in the video signal.
With video input connected again, I traced the problem back from the output of the video amp output tube V307 back to the output of pin 7 of the V305, the 6AL5 video detector output as shown in attached photo.
This video signal can be seen as a higher level after blanking. It seems to be causing the white bar .
I replaced the 6AL5 with another good 6AL5 and there was no change. Could this problem be before the video detector?
With video on the screen, the entire picture is shown. The white bar is superimposed over the picture. I am at a dead end and don't know where to go from here.
Old 11-11-2019, 09:33 AM
If you pull the 6AL5, is the white bar still present?
Old 11-11-2019, 10:21 AM
Notimetolooz's Avatar
That is an interesting problem. Seems like a delayed version of the horizontal sync is getting into the video. Are you certain you didn't miswire something? Maybe it is coupling to the local B+ supply. How about a schematic.
Old 11-11-2019, 11:17 AM
Workin' Late Again
Here's the horizontal section from Sams. I don't understand why when I link to my Flickr url here on VK it always looks blurry when I click on the link and does not zoom to the same size as when I view it directly on Flickr. Anyone have any idea's why that happens? [edit] I might have found the issue, see if the second link works better for ya.
https://live.staticflickr.com/65535/...a5a6838a_b.jpg
https://www.flickr.com/photos/152661...posted-public/
And here's the flyback end of the Horizontal section.
Old 11-11-2019, 12:45 PM
How to link a Flickr image so it shows an image of desired size instead of just a URL:
Go to the image (your second link, for example) on Flickr.
Click the Download arrow at lower right and select "View all sizes"
On the "Photo - all sizes" page, select the size you want.
Right click on the image and select "Copy image address"
Back on videokarma, "go advanced" to show all the options for your post.
Click the "Insert Image" icon (looks like a mountain and sun).
A small window pops up. Press Control-V to copy the URL in the box.
Old 11-11-2019, 01:24 PM
[IMG]https://live.staticflickr.com/65535/49050147042_637b99acb5_k.j]
That is a bit too big...IMO.
I prefer this method for speed/ease of use YMMV. http://videokarma.org/showpost.php?p...&postcount=238
Old 11-11-2019, 02:05 PM
Workin' Late Again
Thanks, but too much information. I just wanted to know why the image was blurring out with the link I'd picked. Maybe it's just me, but for viewing a schematic I prefer clicking a url link and then being able to expand and pan around the image rather that have a blown up portion of the image showing directly in the thread.
Old 11-11-2019, 03:32 PM
When I pull the 6AL5 detector, the line goes away. I am sure I have not miswired any caps.
With no video there is no line. If I lower the contrast, the line gets dimmer. If I adjust and increase the contrast it gets brighter at the mid point of the pot as shown in photos, then decreases and shrinks back as I increase contrast as it seems to overdrive the circuit as shown in the photo with thinnest line. This test was done with my signal generator with a cross as shown.
