Old 11-20-2019, 07:51 PM
RCA Victor portable TV from the 1950s
Hello everyone today I finally got the old TV I was talking about, it's a 1950s vintage RCA Victor 12" B & W portable TV that is in a metal and plastic cabinet with a handle on top and it's white colored.
Interesting thing is that it's got both VHF and UHF tuners on it and built in antennas.
Any information about the TV?
Pictures of the unit in question posted below.
Old 11-20-2019, 08:32 PM
Same set (17inch) in maroon:
http://www.tvhistory.tv/1959-RCA-170P063.jpg
Old 11-20-2019, 08:35 PM
michaelz michaelz is offline
Cool.
Old 11-20-2019, 08:41 PM
Cool, thanks for the link. So, mine doesn't power up when you turn on the power switch, and it does have all of its original RCA branded Tubes in it.
Also was this considered a high end set?
Old 11-20-2019, 08:45 PM
check filament of all the tubes.
Old 11-20-2019, 09:07 PM
This isn't a series string set, it has a power transformer in it, and I don't see any fuses in it.
The tube placement chart and chassis number is missing from the set so I don't know if I can find a service manual for this TV or not.
Old 11-20-2019, 09:11 PM
Here's some pictures of the inside of the TV.
Old 11-20-2019, 09:37 PM
Kevin Kuehn's Avatar
Workin' Late Again
Very nice! Looks like it'll clean up real well, should be a fun project. Sams index says 513-2.
Old 11-20-2019, 10:07 PM
I have the same set, 1959 I think, great performer when restored.
It has a fusible resistor I think, that will kill it if it's open.
Old 11-21-2019, 12:09 AM
OK so I think I found the fusible resistor yo were talking about, and it actually tested fine, it said it had continuity according to my continuity tester on my DMM.
But there was one part near it that I wasn't sure about what it was or what it was supposed to be and it appears to be damaged whatever the part is, and it looks to be part of the power supply.
see picture below.
Old 11-21-2019, 12:13 AM
Unfortunately I don't have Sam's Folders going that high, my Sam's Folders only go up to 469 and they aren't even a complete set of Sam's Folders going that high.
Old 11-21-2019, 12:18 AM
That looks like a Thermistor, I seem to recall replacing one in my set. If it is you could just jumper it and power it up with a variac or dim bulb tester.
Old 11-21-2019, 12:30 AM
Just found it, 1.7MB in PDF format, can you provide email address, I send it to you ASAP. see if you can use it.
Old 11-21-2019, 12:59 AM
You mean the mystery part?
If so what was the purpose of that thermistor in that spot, and how do I jump it?
Old 11-21-2019, 09:22 AM
Dubis7's Avatar
Dubis7 Dubis7 is offline
Alchemizes cash to tubes
My understanding is that thermistors are a sort of heat-responsive resistor. It starts out with high resistance to prevent current inrush on power up, and quickly drops to basically 0 as the set warms up. It's a protection thing, but you should be safe to eliminate it for now.
You could literally use alligator clips on either side or solder a wire to bypass it for the time being. I'd recommend replacing it if it's bad, though.
Feel free to correct me if I'm wrong. I'm not nearly as experienced as some people here.
