Old 12-12-2019, 04:50 PM
DeLorean00 DeLorean00 is offline
Ozone smell HV voltage cage.
I am working on getting this 1950 Mercury 106 chassis up and running. Last night I did my first successful power on. Now I am tracking down remaining issues.
So I am getting an ozone smell coming from the HV cage, I am not able to see anything arcing or hear much of anything. I can see that it appears this is not a new issue as there is a lot of insulating goop all over the socket of the 1k2.
I am going to wait for dark and try to look again for any signs of arcing but I am not wanting to run it very long. I ordered some MG Chemicals Super Corona Dope and I am thinking about just painting it on over the stuff that is already coated if I cannot find where it is exactly arcing.
Does anyone have any tips on what I should do? I realize I do ask a lot of questions but I am new to TVs and am learning as go.
Thanks in advance!
Old 12-12-2019, 05:28 PM
Any conductor with sharp points will be more likely to produce corona. It looks like there are a lot of them there. More insulation may do the trick, but if not, the solder joints may need to be more rounded.
Old 12-12-2019, 05:58 PM
Thanks! Well, I found without the HV cage it stops. So hopefully that will help me find where it is producing the corona.
Old 12-12-2019, 06:06 PM
ohohyodafarted's Avatar
Bob Galanter
Get some GC Carona Dope and coat all bare solder connections.
ME http://AntiqueTvGuy.com
Old 12-12-2019, 07:47 PM
irext's Avatar
irext irext is offline
Try breathing over it in the dark. The moisture in your breath will encourage any weak points to produce a corona.
Old 12-12-2019, 10:02 PM
Thanks! I have it on the way. I ordered some today.
WOW!! That was AWESOME! I did exactly as you said and corona appeared! I can see exactly what pin in the socket that is causing it.
Seriously, thank you. I would have never known this.
Old 12-12-2019, 10:10 PM
While waiting for the corona dope to arrive, I would carefully clean everything in the high voltage compartment -- including the inside of the cage cover -- using rubbing alcohol.
Phil's Old Radios
https://antiqueradio.org/index.html
Old 12-12-2019, 10:33 PM
Phil's Old Radios
Thanks! I am working on that now.
The ozone smell has gone away more or less right now. But it will still come back if I blow directly on the HV rectifier. Is there risk of damaging my flyback or anything if run the test for testing?
Old 12-12-2019, 10:44 PM
So I couldn't keep myself from working on the set a little bit. This is the picture I have after around 5 minutes of run time. Still a few issues to work out and the yoke is not sitting correct but the TV chassis is on its side.
I think is pretty decent for a TV that hasn't ran in 50 years. I was expecting a lot worse. This TV has had a lot of repair work over the years, rebuilt CRT, replacement flyback, a load of different brand tubes, it might even have had the power transformer replaced.
