Old 01-13-2020, 03:38 PM
demy1942's Avatar
demy1942 demy1942 is offline
Panasonic TR-5041P B/W 5" Portable - help
I have this small tv and hooked it up to the converter box and then connecting to the external port using a 3.5mm plug attached to the coaxial cable. When I push the plug all the way in, doesn't really work, if I touch the outside of the port with the tip of the plug, it works better.
Any suggestion on making a stronger attachment to the back?
Other way to attach plug?
Different kind of plug?
Thanks for looking and great site, glad I found it
the plug works much better on my Casio 970
Old 01-14-2020, 08:52 AM
Some of the older portable.sets had a 300 ohm balanced antenna mini jack vs the 75 ohm coax type your using. What you probably need is a 1/8" jack with 2 screw terminals labeled 300 ohm then a 300 ohm to 75 ohm antenna balun. I have such a set up I use for a couple of 60s Sony portable sets of mine.
Anothe morer kludgy option would be to plug the jack you have in then rig up something to connect only the center conductor of the coax to the outer barrel of your adapter.
Old 01-14-2020, 01:36 PM
demy1942's Avatar
Thanks for the response terminal. I was wondering if you can help me out? I am looking on amazon for the materials but I can't find the 1/8" jack with the two screws. All I see is the non solder type. Is there a better place to buy material for tv's electronics on the web outside of Amazon? lot of searching here, sorry do you have a picture of what yours might look like, my issue is the plug goes in but doesn't seem to get a proper contact. Looking online and having no luck!!!
I have this at home https://www.justdial.com/Quick-Push-...on=&show=false
and this I also have
https://picclick.com/2-UHF-VHF-FM-Pl...161352893.html
Thanks
This is what I found? Looks the same as what I have now
https://www.amazon.com/CERRXIAN-Term...030621&sr=8-20
Is this what I am looking for?
https://www.ebay.com/itm/3-5mm-Balun...s/163820114187
Old 01-14-2020, 02:01 PM
The eBay link along with the second link is basically what I have (though I think my version of the eBay plug lacks the balun*). I got those parts from skycraft surplus in Orlando over a decade ago.
The last 3 links should give you what you need...If one 3.5mm ( or 1/8" when these were new) jack don't work, try the other. The Amazon jack with the second link balun should give 300 input.
* I'll see if I can find it and check when I get home tonight.
Old 01-14-2020, 03:24 PM
demy1942's Avatar
You know, I looked on amazon and they don't have that kind, I'll mess around with it and I was wondering, what does the black part of the plug do? Is that just a method built into the plug to make the fit tight? I used the same set up on my portable casio 970 2.3" and it works fine. I think the jack for the tv is a little too wide in diameter to make proper contact with the plug. I'll maybe figure out a way to connect to the outside. I love this tv, had one in 1980/81 and it was stolen from me at work.
I have a few other b/w tv's coming so I will see if I have the same problem
Thanks for helping.
By the way, I have a 1980 ONKYO stereo receiver, they don't look to be worth much
Old 01-14-2020, 04:09 PM
On the eBay one there is a balun built in to the black part....on this Amazon one the black part looks to be just a handle and wires straight to the terminals from the 1/8". .https://www.amazon.com/CERRXIAN-Term...030621&sr=8-20
Your first 2 links are 75 ohm to 300 ohm baluns (which are bidirectional usually ). Those baluns do 2 things: they match impedances between different impedance transmission lines, and they convert between BALanced and UNbalanced (hence the name) transmission line...
If the connector on the set isn't making contact with adapter then either the connectior on the set is non-standard, has dirty contacts, or damaged. You could spray contact cleaner, replace it, or if you plan to keep the plug plugged in to the set for years on end you could try placing a bit of aluminum foil between the plug and socket to shim it and make electrical contact...it ain't the most elegant solution but if it works good enough for you that is all that should matter.
Old 01-14-2020, 04:35 PM
demy1942's Avatar
Thanks Tom for the answer, I actually tried to wrap it around, what about if I built up some solder, let it dry, file down to a tight fit. Would that work the same way? I am new with any electronics work.
Old 01-15-2020, 09:18 AM
The thing about soldering in there is, if your iron tip is actually small enough to fit, that if the body of the jack is plastic you can melt it faster than you can get a solder bead in there... I'd just change the jack on the TVs PCB at that point...if you want something original look for a junk monophonic cassette recorder from the period with a mic input jack and use solder wick or a solder sucker to remove the jack from the tape recorder PCB, then install on the TV.
I checked my adapter last night and it is identical to the eBay part.
Old 01-15-2020, 06:34 PM
demy1942's Avatar
Thanks Electronic, on the outside of the port it has a symbol of 75ohm I will try to attach picture, I decided to open up battery compartment, what?????? Batteries still in it!!!!!!!! Luckily only a little leakage on plastic sleave I wonder how old they are?
I might take the cover off and try to figure out why it only makes good contact to the tip of the connector. I like some of the other tv's that have the screw terminals on the outside. I tried the aluminum foil, no dice on that one.
Just searching, what about something from a radio that has an external port?
Old 01-16-2020, 09:05 AM
Those might be the original batteries it shipped with... I'd put them in a plastic container and keep them with the set.
Getting a better look at the connector on the side of the set it looks like Panasonic tried to make the connector proprietary... it looks like that plastic lip recesses such that the plug can't fully seat against the metal ring of the connector like it needs to inorder to make proper contact....also there appears to be a switch built into the top of the lip that would engage with a plastic connector that matches the inner profile of the lip. That switch probably switches between the internal ant and the jack...it may be hard to keep the set unmodified and use a non-original adapter. If you don't mind hacking the set you could probably grind the lip down with the dremmel and shim the switch up.
Here is a goofy trick you can use for sets that don't have an external ant jack. Radio Shack sells these small leads with alligator clips on each end. When I needed to test my Philco Safari I just took a clip lead and grabbed the antenna with one end and the center pin of the coax with the other.
If you have multiple portable sets and want to run many at once and not be tethered you could get an agile modulator and rig up a low power transmitter that covers just your property. I got a Blonder Tongue AM60 a few years ago and no longer tether my sets directly to signal sources. There's plenty of discussion of this here on VK if you run a search.
Old 01-16-2020, 06:35 PM
demy1942's Avatar
Good eye electronic, it does have that plastic lip and the only weird thing about that is the reason for this on an external port for an antenna. I had the TV when it came out in 1980 and it's a strange setup. That plastic piece is almost round but for a short piece. I do have those alligator clips and I might ground down the plastic in the back.
I bought a 2" Sony Watchman and it works perfectly with the same external antenna plug.
Thanks for helping out and the suggestions. I just wonder why they made a semi circular piece of plastic like that.
I just looked at the picture again, yeah it has that little piece of metal hanging down, but this is for an external antenna, crazy idea, I wonder what kind of jack was used?
Old 01-16-2020, 07:02 PM
Tom C is on the right track. That adapter is too fat to seat in.
Sony made one that was plastic & you could probably file it down
if need be.
This set is the ONLY one I have ever seen with a 75 ohm UHF input.
Normally its separate 300 ohm or one 75 ohm for both.
Old 01-16-2020, 07:12 PM
demy1942's Avatar
I might try to file down the 3.5mm and make it the same shape. Crazy design, I might just try to place a coax wire into it
Old 01-17-2020, 06:40 AM
demy1942's Avatar
You know, I looked at it again, that is just an optical illusion. It's the reflection of the 3.5mm. Crazy picture
Old 01-17-2020, 03:30 PM
demy1942's Avatar
Electronic,
What is this for, igot an extra digital to analog converter and this wire was in it?
