Old 04-14-2020, 09:25 PM
hfrazier hfrazier is offline
Wanted - Zenith Horiz Osc Assembly for chassis 28F20/21/22
Part number S-15041 from a Zenith parts chassis, if anyone has one to spare, I'd be willing to pay! My set unfortunately had a broken center tap lead on this coil due to prior physical damage before buying. At first I was able to fully restore the set and re-solder the winding but unfortunately after a while the connection failed. At this point the coil may need to be replaced or re-wound, and I'm trying to avoid that!
The coils are mounted on a sub-assembly board, usually covered in beeswax.. picture attached. Any help locating one or a suitable replacement would also be greatly appreciated!
Harrison
