Old 05-09-2020, 11:11 AM
Ram x050 flyback spec sheet
Hey all I have a ram x050 flyback that is a replacement for the thordarson fly58 but the numbers are different between the both. There are several numbers in different places as opposed to the fly58 so I need to find out where for example, where number 2 goes on the ram, ect . The small paper that usually comes with a flyback is what I am looking for if at all possible for the ram.
Old 05-09-2020, 06:25 PM
Polaraligned's Avatar
Polaraligned Polaraligned is offline
Old 05-09-2020, 06:40 PM
Originally Posted by Polaraligned View Post
Is this infact the replacement for the thordarson fly58 ?
Old 05-09-2020, 06:46 PM
Give me the make and model/chassis number of the set and I will look it up in the RAM catalog.
The RAM catalog doesn't have a cross reference.
Old 05-09-2020, 07:02 PM
Well the problem with that is my set has like 4 different SAMs and the 2 I have are different but the flyback in this set has a fly58 and I was told that the ram x050 crosses to a fly58 but the connections and ohms are completely different on the ram. The set I have is a cbs Columbia 22c38 1954. I don't know what you may find for that set. I got the ram from ETF but now I have to send it back because it's not for this set. I was never able to find a chassis number unless the 22c38 is the number but this chassis is different then the 2 SAMs I have and the SAMs don't list a thordarson fly58 , it's weird.
Old 05-09-2020, 07:13 PM
Ram catalog says X075 for your set. I might have one. I will look.
Old 05-09-2020, 07:22 PM
What worrys me is getting the wrong one because there are 4 SAMs and there are chassis in the 18s several of them the one SAMs I have shows a fly5 from thordarson and the chassis is so close to mine it would have been very easy to make a mistake thinking that the fly5 was right if it weren't for the fly 58 in my set that is stamped on the flyback as fly58.
Old 05-09-2020, 07:24 PM
Does this look correct?
I have one brand new in the box if you want it. Let me know and I will list it on Ebay for you ($14.99). It is easier selling there as I can just print the postage right from Ebay.
Old 05-09-2020, 07:31 PM
It looks good so let me check my set against this and I will get back to you tomorrow. And thanks for the help. Tim
Old 05-09-2020, 07:41 PM
Oh boy this set is nuts the x075 shows the horiz cap is number 2 but mine is number 9 so I'm sure the number lineup should be the same for all different brands for the specific tvs. So I guess this means it's not the right one.
Old 05-09-2020, 08:49 PM
Tim's Avatar
Tim Tim is offline
I checked the Thordarson catalog and the FLY58 is the correct one for your chassis 22C38. Go by the schematic more than the terminal numbers.
Tim
Old 05-09-2020, 08:54 PM
anyone have a ram xo-36 spec sheet?
Old 05-10-2020, 05:12 AM
I know I have the correct flyback in my set but I can't go by a schematic of another flyback unless I have the flyback schematic of my set to compare, which is yes the fly58.
Old 05-10-2020, 06:56 AM
Old 05-10-2020, 12:40 PM
from what I has seen, the ram xo-36 is a replacement for the rca 630ts / fada clones
