Old 06-05-2020, 02:33 PM
hi_volt's Avatar
hi_volt hi_volt is offline
Vintage TV and Radio Nut
Just Purchased - 1957 Admiral Imperial Model 414
Just scored this on the Bay. I had a blonde one of these when I was 11 years old. It's all monaural, but will rock the house with that 15-inch woofer and 30-watt amplifier. This was a high-end unit back in the day with an audio compensation control. I just need to get it shipped to Tucson.
Old 06-05-2020, 04:53 PM
DavGoodlin's Avatar
Motorola Minion
Nice one! I recall finding the blonde version in a dumpster long ago, only salvaging the amp chassis. Does that have parallel push-pull 6BQ5?
-Dave G
Old 06-08-2020, 09:20 PM
hi_volt's Avatar
I believe you're correct. I can almost read one of the tubes, and they look like four of the 6BQ5 tubes. Two parallel push-pull sets based on the tube layout.
