Old 06-29-2020, 02:58 PM
Jon1967us Jon1967us is offline
Injecting composite video into a Hot Chassis set?
The TV I'm troubleshooting, 1957 portable Trav-ler is a nice little set, with a good CRT, is worthy of restoration but has some video sync issues. I'm attempting to feed a composite signal from my BK 1249A into either the video amp grid or the 1st IF grid, as a way of process of elimination.
I haven't done this before (I've only restored a couple sets) and was wondering if
A. It's safe or possible to inject a signal onto a hot chassis set, feeding the signal from the generator onto the grid of the Video Amp, and ground to chassis. I remember reading something about this and suspect this isn't a wise idea.
B. If not, is there an alternative way to bypass the tuner, and inject signal somehow?
I assume we're connected to the "Video" output with "IF" selected.
And injecting into pin 7?
