Old 07-01-2020, 12:43 PM
Jon1967us Jon1967us is offline
Sync Separator Diode Replacement
TITLE CORRECTION: HORIZ AFC DIODE REPLACEMENT AND ASSOCIATED PROBLEMS
I’m working on a ‘57 Travler portable b&w which appears to have major syncing issues. The diode shown below was open and needed to be replaced.
https://ibb.co/sKw2zqP
The stock diode was a Selenium, was open and I replaced it with a Silcicon Schottky 1N5408.
I assume this is the sync separator diode? The waveform somewhat looks okish, read at the “-“ end of the diode, but jumps around and looks unstable.
No waveforms are read at both pin 2s of the Noise Canceller (V6) and Sync Sep (V5) and I’m concerned that this may be the wrong diode to use, voltage drop compensation aside.
Waveforms look ok before the Very Osc and after the Vert Outputs.
Is the Schottky ok to use or should I source a different type, even a Selenium? I know my Schottky is installed correctly with the correct polarity at least.
Old 07-01-2020, 12:47 PM
Image of Diode, negative leg waveform.https://ibb.co/W28sG08
Old 07-01-2020, 01:31 PM
https://youtu.be/fM1fGqM99WEMovie of same
Old 07-01-2020, 01:53 PM
Which way did you install the diode? Seleniums are often marked with a plus sign(+) on the cathode end. With Si diodes, the banded end is the cathode.
Old 07-01-2020, 02:07 PM
I have the cathode indicating band corresponding to the cathode “+” indicator on the Selenium in the schematic.
In other words, the cathode side of the Si diode is in the same position of where the “+” side would’ve been on the Selenium. I guess I’m aware of “discrepancy” between how Seleniums used to be notated on schematics. Anyway, if I orientate the Silicon the opposite direction, hardly any signal is displayed on screen, which was the situation prior to replacing the bad Selenium diode.
Old 07-01-2020, 02:31 PM
Looks like the diode is used as a phase comparator (normally a dual diode is used). Never seen a single diode used there before. The circuit depends on a feedback pulse which would come in via C50 and R60.
If there's no waveforms present at the sync sep and noise cancellor stages, the the signal loss must be somewhere 'upstream' of there. Probably be helpful if you could post a fuller schematic.
Old 07-01-2020, 02:50 PM
Maybe the schematic is incorrect if it’s just showing a single diode. Sams are not known to be perfect...
Here’s a couple shots of the full schematic for this model:
https://ibb.co/SXnLWdX
https://ibb.co/4FXh7Rv
Old 07-01-2020, 02:58 PM
It’s weird, I have a schematic for a year later model, and that one labels it as a Horiz AFC, but one of the legs (of the dual diode) has no connection. Schematic otherwise looks identical.
https://ibb.co/m40Ftj9
Now we know it’s a Horiz AFC. Wish I could change the thread title.Thanks for the help by the way!
Old 07-01-2020, 03:27 PM
Does the vert lock in ? If so odds are its not in the sync sep stage.
Diode probably could use any little signal diode like the one
used as the video detector. It should just pass the positive H sync
pulses.
BTW any markings or part #s in the Sams ?
Old 07-01-2020, 03:47 PM
pulses.
It’s weird but after some component replacements yesterday, on stuff that had drifted way out of tolerance, I can’t adjust the vertical anymore. After these replacements the picture seems to have degraded, even though the replacements are close to spec. I’m using a BK NTSC pattern generator and it’s almost impossible to get just the horizontal lines dialed in, let alone the staircase pattern as that pattern is repeated vertically. This set is a nightmare.
Nice strong CRT and deflection though.
Old 07-01-2020, 03:50 PM
https://ibb.co/PwdVKSrPic of Lines pattern on screen (sorry for angle)
Pic of staircase or bars
https://ibb.co/XCgTxLm
Maybe the pics spell out the problem better for the veterans
Old 07-01-2020, 05:44 PM
What kinda display do you get using a regular signal source (e.g., VCR, cable box etc)?
Old 07-01-2020, 05:56 PM
Pretty much the same. Barely discernible, washed out image that repeats horizontally.
Note this set is some kind of transitional model or oddball. Aside from an occasional different value, the set, although it matches the schematic that I posted, looks more like a later model, with the tuning knob on top, not on the side.
The dead diode I replaced was a dual diode (series arrangement) with one leg unconnected, just as in the year later schematic. The year later schematic has an almost completely different tube compliment. I can post that one as well.
I’ve pretty much replaced every wax and electrolytic capacitor and only left in originals that tested within tolerance. I haven’t really messed with the ceramics.
Old 07-01-2020, 07:04 PM
"Repeats horizontally" suggests the horz sweep is 'waay off frequency. I wouldn't use a pattern generator, but rather a regular signal source to get it on frequency first. Then see what the actual video looks like. You can tell a lot more that way.
You indicate absence of any waveforms at the sync sep. Sync is picked off the video chain right after the video output. Check peaking coils L7 and L9, and coil L8 for continuity for starters. And check plate voltage on the video output (pin 9).
Old 07-01-2020, 09:21 PM
Thanks. I have indeed used a regular signal source, RF on the antenna terminals, IF, and composite in the IF chain and after the detector. Same result.
Per your suggestion, I did test resistances on coils L7-9 and everything tested fine.
Plate voltage (varies with Contrast control) tests normal.
