Old 07-21-2020, 06:09 PM
Hawkwind's Avatar
Hawkwind Hawkwind is offline
TV DXer...
FM Radios with channel numbers???
Well, ???
You know, an FM radio with channel numbers on the display/dial...
Old 07-21-2020, 06:53 PM
As in FM receivers that can pick up the sideband text some stations broadcast that contains the station name and whatever was currently playing?
Old 07-21-2020, 07:04 PM
Some early 45 mHz band FM sets displayed channel 21 to 99. Ch 21 was 42.1 mHz and the top end of the band Ch 99 was 49.9 mHz.
Old 07-22-2020, 09:19 AM
A few of the early post war band FM recievers did that too IIRC Capeheart was one such make to do it.
Old 07-22-2020, 01:07 PM
The audio for TV channel 6 (NTSC) was within the FM band. Local station used to advertise listening to it on your car radio.
Old 07-22-2020, 03:16 PM
mr_rye89's Avatar
mr_rye89 mr_rye89 is offline
Pre war FM band. Common Philco models include 42-390/42-350 (same chassis)
Old 07-22-2020, 03:50 PM
AdamAnt316's Avatar
Collector of heavy things
Actually, the channel numbers used for pre-war FM were, as jr_tech mentioned above, 21-99, corresponding to the last two digits of the 42.1-49.9 frequency range. The 200-300 channel numbers correspond to the modern 88-108MHz FM band, with this chart showing how they're assigned.
-Adam
Visit my site!
Old 07-22-2020, 04:43 PM
-Adam
Or calculated:
Channel number = ((frequency - 87.9) X 5) + 200
Old 07-24-2020, 10:49 PM
The Philco 42-350 and a Philco 42-355 are shown on this page from Wa2ise:
http://www.wa2ise.com/radios/fm45.html
Interesting to note that the channel numbers are contained in the call letters of some of the stations, such as W47NY.
Old 07-24-2020, 11:18 PM
AdamAnt316's Avatar
They do the same thing with FM translators nowadays. For example, WGAM 1250kHz in Manchester, NH has a FM translator on 103.5MHz with the callsign W278CJ.
-Adam
Visit my site!
Old 07-24-2020, 11:52 PM
As late as the 1970s, some FM stations were still identifying with their call signs and channel number. I live near Cleveland and remember one such station on 105.7 MHz identifying as WKYC-FM, 105.7, channel 289, Cleveland, in the mid to late 1970s.
FWIW, the station was operated by NBC (the radio network was still in existence then; it was disbanded, however, some time [read decades] ago) at that time (1955-65 and 1965-'80). The AM station is now WTAM 1100, the FM is now WMJI, and the TV station is still WKYC-TV; however, the AM and FM stations changed owners and call signs several times since the '70s and are now, respectively, talk and classic hits (a.k.a. oldies) stations. The television station is still WKYC-TV; however, it is now owned and operated by Tegna Media and has been an NBC-TV affiliate since its initial sign-on in 1948.
Old 07-29-2020, 09:04 AM
TV-collector's Avatar
TV-collector TV-collector is offline
There are some german radios that have that information on
the scale.
Regards,
TV-Collector
Scotty, beam me up, there is no more 4/3 Television and AM radio in Germany!
