Old 09-04-2020, 05:34 PM
TinCanAlley's Avatar
TV no one remembers, not even the internet LOL!
Back in 1987 I purchased a TV from a shop on Hollywood Blvd. It was a Kenwood KMT-1026. I had it up 'til 2000 when I gave it away. The other day I was going down memory lane and tried to remember the model number. I searched the internet, but you would think Kenwood never had a TV with their name on it. I searched ebay and found squat. It wasn't until I remembered model number things moved along. However, even with the entire model number, I was only able to find an owner's manual on ebay. Not pics on google, no other real results on any searches.
Anyway, seems kind of odd it is almost as if this set never existed.
I've attached a scan of an old pic of TV. My best guess, 1994.
Old 09-04-2020, 08:11 PM
It probably barely existed & the name may have been rented out
to make a few bucks. Never saw or heard of one. Be interesting
to see who built it.
Old 09-05-2020, 09:50 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
...Be interesting
I think it was NEC-built but not sure. We were a Kenwood authorized service center back in the day and I recall seeing a Kenwood branded TV or two.
Old 09-05-2020, 08:35 PM
Wish I had kept it. Didn't think I'd want an old CRT once I got a rear projection, then LCD, plasma and now OLED, but I have a couple and use them regularly for old media and video games.
Old 09-05-2020, 09:51 PM
I corrected a typo in the model #. It is a 1026, not a 2026. That was the higher end model with speakers up front. I did manage to find on ebay a 1986 kenwood video brochure. It features the top corner of the TV on the cover and specs on the back. However, the seller put up a low res and slightly blurry image and no images from the inside what would show the set.
Old 09-17-2020, 12:24 PM
rpm1200's Avatar
rpm1200 rpm1200 is offline
I have a Video Magazine buyer's guide from 1988 that I saved. It has listings for the Kenwood TV line including a couple of AV systems. There are pictures of the KMT-2026 but none of the 2016A. The same issue shows TVs from Pioneer and Yamaha and a Technics AV system, so there must have been somewhat of a push for audio companies to come out with video components at that time.
Old 09-17-2020, 03:14 PM
These were at the end of the component TV try. Some like Zenith
had separate tuners, monitors, audio, switchers, MTS decoders etc.
Others were just full TV,s with lots of features & jacks. The
original idea was to be able to put the best mix of brands like
you would with stereo components.
Old 09-17-2020, 04:18 PM
What is funny is the part about it being cable compatible. I assume it was for some systems, but not Communicom in Los Angeles back in the late 80s. The TV had three f-type connectors on the back. You put the cable from the wall into the first, then the input of the cable box connected to the second, with the third coming out of the box to the TV. From there you were supposed to be able to switch the TV to ant A and be able to use the TV's tuner to view any cable channels not "scrambled." For "scrambled" you would switch to ant B and use the box with TV on channel 3. I tried this and every morning my box wouldn't work. I would have to call the company and they would send a reset to the box. After this happened for the 3rd time, I figured it had something to do with the TV. So I called for tier 2 support and it seems every night the company poles the boxes. If they don't respond to 3 attempts, they disable them. So when my TV was off, the query wouldn't be passed through to the box.
Old 09-18-2020, 05:52 PM
AlanInSitges's Avatar
Can confirm that the remote handset in the picture appears to be an NEC.
Old 09-19-2020, 11:30 PM
Yeah, that one is for the 2026, but the 1026 is pretty much identical, but more square around the edges. It is odd how the 1026 has a removable glass front. I guess they wanted a flat look. It did look cool back then.
Old 02-08-2021, 09:11 PM
MX70's Avatar
MX70 MX70 is offline
Kinda looks like a JVC; aren't/weren't Kenwood and JVC in bed with each other ?
Old 02-08-2021, 10:12 PM
Back around 2000, my electronics instructor in college gave me a Kenwood-branded set that was very similar, if not the same set. The one he gave me was in a wooden (well, particleboard) cabinet and I think it had a glass in front of the CRT. It was definitely an NEC-built set. Unfortunately, it's long gone now.
