Old 11-07-2020, 08:05 AM
kf4rca kf4rca is offline
Sad, Sad Samsung
This little Samsung UN32J525DAFXZA made it to the roadside in less than TWO YEARS after leaving the factory. Problem: vertical lines, bad TCon board.
Most likely its former owner will not buy another Samsung.
And I'd be reluctant to put another TCon board in since it might fail early also.
Sad, sad Samsung.
Old 11-07-2020, 06:18 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
2 years.. that's a shame. Can't you find a board cheap on ebay ?
My 2009 19" Samsung I paid over $300 for then that I use on my music system keeps on truckin'...
Old 11-07-2020, 10:42 PM
dishdude's Avatar
dishdude dishdude is offline
Probably paid $130 for it new. People were paying $130 (in 1990's money) to repair a 27" TV in hopes of getting a few more years out of it.
Old 11-09-2020, 06:58 AM
JohnCT's Avatar
JohnCT JohnCT is offline
That's not a bad TCON, that's a bad display. Remove one ribbon from the TCON to the display and run it with half a pic. If the picture is good, the disconnected side is bad. If it's the same, reconnect the ribbon and remove the other side.
If you can get half a good pic, let me know. There's a trick to "fixing" those.
Old 11-09-2020, 07:23 AM
Thanks John, I'll try that.
Old 11-10-2020, 01:56 PM
If either ribbon is disconnected, it will not make an image.
Must be an interlock circuit in there.
I've got a UN40H5203, that I DO believe has a bad panel, that I can try to sub the TCon board from.
Might not be a bad idea to pull the bezel and see if something got spilled in there, because these Samsungs have the panel connections on the bottom.
Old 11-10-2020, 06:11 PM
JohnCT's Avatar
Yeah, some of these toilets won't run with one ribbon. And good call on the spooze in the address board. In the trade, we call that "Windex Syndrome". If you see any green goo on the board, it's too late. If it's clean, there is still another trick to try.
