Old 11-21-2020, 12:22 PM
Hawkwind's Avatar
Hawkwind Hawkwind is offline
TV DXer...
Scanner Antenna...
Can any one recommend a Discone antenna with a VHF-L (USW) whip?..
Old 11-21-2020, 06:17 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
I've had a Tram 1410 up for 15-20 years. Good quality. They make the 1411 with the vertical whip and lower freq xmit range. Transmit bands 26MHz/27MHz/46MHz/49MHz/72MHz/144MHz/220MHz/440MHz/900MHz/1,290MHz
https://www.ebay.com/itm/TRAM-R-1411...Cclp%3A2334524
Old 11-21-2020, 10:50 PM
Hawkwind's Avatar
TV DXer...
Hey, thanks for the reply.
I've heard of Tram before and will look into them...
Old 11-22-2020, 05:39 PM
Tram built super high end CB's & were in Winnisquam N.H.
Right beside lake Winnipesaukee, not where you would expect
an electronics mfr ! I would guess a tiny building lot is 500-1,000 K now.
Anyhows they had a relationship with Diamond of Japan who
built there small CB's. Big bases were still US made. I bet the Tram
antennas are built by Diamond now. Nice to see an old name pop
up again.
Old 12-08-2020, 05:14 PM
Hawkwind's Avatar
TV DXer...
Diamond...
Thanks for the helpful replies. After reading reviews of the Tram I went with a Diamond instead. Plus I'll get the correct coax with the correct connectors for the first time...
Old 01-31-2021, 11:56 AM
Hawkwind's Avatar
TV DXer...
Bring on the sunspots!
I'm all set! Yes, the scanner is a bit of an over-kill I wish I still had my PRO-2006. Antenna is a Diamond D130NJ with 50 feet of LMA 400 coax cable. Scanner is a Uniden SDS200...
Old 01-31-2021, 12:04 PM
Hawkwind's Avatar
TV DXer...
Oops...
I meant to use this image of the antenna...
