Old 11-23-2020, 06:01 PM
Polaraligned's Avatar
Polaraligned Polaraligned is offline
Difference between Motorola TS-18 and TS-18A chassis?
Title says it, any noteworthy improvements to the "A" version of the chassis?
Old 11-24-2020, 11:19 AM
Vertical retrace blanking and a modified contrast control I believe. I'll try to dig it up in a Wallace Teleaide.
Old 11-24-2020, 11:54 AM
nasadowsk's Avatar
Damn does run fast…
The TS-18A is Canadian.
"TS-18, eh?"
Old 11-24-2020, 02:57 PM
Here's a portion of the schematic. Pin 3 of the 7JP4 is grounded in the TS-18. Here it is a fed a blanking pulse from the vertical circuit.
They also added some taps and caps to the contrast controls. Probably a few other minor tweaks.
https://flic.kr/p/2ka82XL
Old 11-24-2020, 07:51 PM
Thanks Bob. I appreciate it. I wonder if it is worthwhile to upgrade a TS-18 to the "A" version. Sounds pretty minor to do.
Old 11-24-2020, 08:42 PM
Absolutely as far as the retrace blanking goes. I've done that the every TS-4 and TS-18 chassis I've restored.
You would need a rather specialized potentiometer for the contrast mod. Probably the only source is to scavenge one from another set.
Old 11-26-2020, 06:33 AM
Thanks Bob!
