Old 12-15-2020, 12:05 PM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
HV anode question
I'm in the process of reassembling my 1964 Admiral roundie after taking it apart for repairs a long while back. I got it back together but the HV anode is not firmly attaching to the CRT (21FJP). The little metal prongs are clipped in but not tightly. I can see the rubber cap is ~ 1/8 of an inch from the CRT bell, definitely not sitting flush and the whole thing can be wiggled. Is this how it should be on a 60s set? It's been so long since I disassembled it I don't remember how it was, but on my more modern stuff it's definitely a tighter fit.
Old 12-15-2020, 12:21 PM
enough play to remove it without undue right and the ability to slip an HV probe under it are needed but It should probably be tighter than you make it sound. You could get arcing which will cause noise in the picture and could cause damage to the CRT in the worst case.
In some cases the metal prongs get bent out of shape or pull part way out of the suction cup, in other cases the suction cup hardens in a peeled back position and goes bad. If you think you can fix the original go for it, otherwise probably good to scrap a BPC and harvest the suction cup and HV lead and use what you need for the roundy.
Old 12-15-2020, 04:32 PM
SpaceAge's Avatar
Thanks. I’m guessing I bent it. I’ll get some pliers and see if I can figure it out.
