Old 01-19-2021, 12:03 AM
billanderson billanderson is offline
looking for replacment RCA trk-12 radio dial panel
Hello,
I am finishing up the restoration of a nice trk-12 and had the mishap of accidentally damaging the bakelite radio dial bezel and chipping the corner off of it, not enough left to glue back on, thought I would ask here if anyone has one that they will not be using or one from an abandoned restoration project...I can be contacted at [email protected] or 404-272-7131
thanks!
Bill Anderson
Old 01-20-2021, 11:19 AM
rld-tv01's Avatar
rld-tv01 rld-tv01 is offline
Looking at the bezel http://myvintagetv.com/rca_trk12.htm. You might be able to make a mold from the good side and flip the new piece 180 degrees to use as replacement part to glue on to the chipped side. The new part would have to be dyed colored while mixing the solution or painted afterwards to match the color of the bakelite. You could also similarly reproduce a whole new bezel.
