Old 02-16-2021, 02:55 PM
govee govee is offline
B&K 1077B questions....Fixed
I decide to get my 1077b out as I am working on a GE 10T1 that needs trouble shooting. I picked this up a while ago and made a bad assumption based on limited test. I had previously turned it on an I got a nice purple glow on the front of the crt. I mistakenly assumed all is well. It is not. I tried it first on the the ge that has no picture an deiced i really needed to verify the 1077 works. I hooked it up to my admiral 19a11 and no image. Today I decided to look further into it and as it eats up a lot of bench top space I hooked it up to my flat screen (old non smart) via its cable/antenna connection. There is something there. The flat screen looks like it needs the horizontal hold adjusted. Since there is no such control on it I was wondering if there was a control or circuit in the 1077 would cause or adjust this? The video is a black//purple large rolling block that is about 30 percent of the screen height but full width and is separated by a large static block that would fill the rest of the screen height if not rolling. If I adjust the RF attenuation pot I can make the black//purple image disappear. The tvs input is set to antenna vice cable.
A few images below
Andy
Old 02-16-2021, 09:05 PM
Since your flat screen set says weak or no signal even with the RF turned up, it is possible that either the B&K or the flat screen TV is set to the wrong channel, and the TV is trying to find the right frequency. Make sure your TV is set to broadcast mode, not cable mode.
Old 02-16-2021, 09:08 PM
Do you have the B&K lid closed? It will pick up ambient light (especially fluorescent) and produce horizontal hum bars in the picture.
Old 02-17-2021, 12:43 PM
I checked and channelization is correct. The tv is setup for air( I believe this is the same as broadcast). The image does not change with the top open or closed. I pulled the tubes one at a time on the video side of the device (not high voltage side) and there was no change to the image when any tube was removed.
Andy
Old 02-17-2021, 01:32 PM
I am not sure what kind of lesson I just learned as in most of my limited radio work tubes are rarely without obvious damage bad enough to make a radio dead. Not work well, sure. My inexperience probably let me call what I was seeing as closer to dead than I should have. I decided to check the tubes in the video side just to be able to answer the question of had I checked the tubes and V13 was completely dead. Filament good, no shorts, but zero emission on either triode (is triode correct?). I subed in a different 12at7 and the 1077B lives again. I added a picture with replacement 12at7.
Andy
Old 02-19-2021, 01:54 AM
12AT7 is a dual triode.
No grid = diode.
Single grid=triode.
Dual grid= tetrode
Triple grid = penthode or beam power tube.
There were octodes...IIRC they were converter stages for superheterodynes.
Old 02-19-2021, 12:14 PM
kvflyer kvflyer is offline
Originally Posted by govee View Post
I am not sure what kind of lesson I just learned... I subed in a different 12at7 and the 1077B lives again. I added a picture with replacement 12at7.
Andy
Very glad for you, Andy. Now, you can move on to another TV!
Old 02-19-2021, 05:04 PM
Kevin Kuehn's Avatar
Workin' Late Again
The old B&K makes a very nice picture on the modern flat screen. First time I've seen someone try that.
Old 02-22-2021, 07:07 AM
kf4rca kf4rca is offline
What model flatscreen is that? Or, the 1077 must have RS170 sync. I have never been able to get my 1076 to picture on anything digital. Or, maybe the newer Samsungs just don't care.
Old 03-04-2021, 01:42 PM
The Tv is a Samsung UN32EH4003F from 2014/2015
