Old 05-19-2021, 02:03 PM
lnx64's Avatar
lnx64 lnx64 is offline
Towing a 94 Caprice
So I will be moving in with my girlfriend within the year, and my Caprice is still running very poorly (backfiring, hesitation) and I am not sure I'll have it running before then with my bad back and other ailments now these days.
It's RWD and I was looking at towing dolly's but now I'm not sure I can do that. You can't tow it backwards for obvious safety reasons, but even if it's in neutral, without the engine running it won't properly lubricate itself when being pulled since it's a 4L60E tranny.
Should I just get a full bed to tow it on or is there something else I can do, like remove the driveshaft?
Old 05-19-2021, 03:36 PM
If its the LT-1 or if it has optispark I think they call it? check the
little vacuum that goes from the distributor to up top. Mine fell
off & it did exactly the same thing. That was on a 94 Roadmaster
with the LT-1.
As for towing I just play it safe & flat bed it. Thats pretty much
every tow truck around here anyhows.
Old 05-19-2021, 04:25 PM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
When was the last time you put fresh gas in it?
Symptom sounds like my '88 S10 4.3 V6 I let sit too long, before the Techron and fresh gas hit the injectors and it suddenly started running normally.
Old 05-19-2021, 04:42 PM
lnx64's Avatar
About 2 years. I didn't think it was that long, but my girlfriend says it was.
Old 05-19-2021, 04:43 PM
lnx64's Avatar
with the LT-1.
Yea it's the LT1, and I just double checked, I did connect that. I used to have so many issues with the Opti, and all of this started happening when I hit a major puddle of water in one of the worst rainfalls I've been in. I am almost certain the opti is shot, since I replaced the plugs and wires.
Old 05-19-2021, 11:09 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Put it on the tow dolly backwards and ensure the steering wheel locks in roughly the center position. Alternatively you could just put it in neutral, but I wouldn't tow it very far. Maybe like 20 miles tops, and not at highway speed. Removing the driveshaft is another option, but a pain in the ass, and messy. All the trans fluid will drain out, especially because the car will be on an incline, being parked front first on a dolly. If you're not moving too far away, just call a tow truck. 100 mile tow can't be more than $200, about the price of renting a two-wheel dolly.
As for the running problem, empty the tank and get some fresh gas in it first. After that, attack the opti-spark crap. Either you have water and corrosion in the distributor cap, or the cam sensor is taking a dump. Granted, it could be something entirely unrelated to the ignition. A major vacuum leak, perhaps.
Old 05-19-2021, 11:22 PM
lnx64's Avatar
Unfortunately this would be a 5 hour drive.
Old 05-22-2021, 03:24 AM
MX70's Avatar
MX70 MX70 is offline
From experience, I would see about renting ( or borrowing) a pick-up and flatbed trailer suitable for car hauling for a haul that long. Check your load every stop and take your time and you'll get it safely there.
Btw I have a '94 Buick Roadmaster with the same LT-1 engine. Love it.
