Old 06-19-2021, 05:39 AM
newzealand's Avatar
newzealand newzealand is offline
Jvc br-s811e s-vhs plug
hi all
i have this player and want to if possible use the s-vhs out on the player to the in put s-video plug on my amp,
i dont have a cable for the player so was hoping some one could help with the pin lay out on the jvc br-s811e out put s-vhs ,
this way i might be able to hard wire a s-video out put or just use single plugs to push into the out put socket that match for the s-video plug at amp end,
if s-vhs and s-video do not work together can any one help so it can be hooked up some way?
thanks for reading this
mike
Old 06-19-2021, 10:45 AM
Ed in Tx's Avatar
Ed in Tx Ed in Tx is offline
Zenith Walton My 1st TV
S-Video will output S-VHS to your receiver. JVC came up with S-Video with S-VHS decks.
As cheap as S-Video cables are I would just buy one. If you were closer I'd give you one of the ones I have.
