Old 08-01-2021, 02:58 PM
sambo521 sambo521 is offline
Yoke replacement lookup
Can somebody look up in their Triad or thordason catalogs and see if there is a replacement for a 95-1666 yoke?
Thanks
Old 08-01-2021, 06:02 PM
For a Zenith I assume going by part number 95-####
Post model & chassis ##'s . Sams usually lists the subs also.
I can check mine but its probably to old for my Sams coverage.
Old 08-01-2021, 09:15 PM
damen's Avatar
damen damen is offline
My 1981 Thordarson guide shows a 95-1666 is replaced by a Y55.
Old 08-02-2021, 08:34 AM
Thanks Damen,
I need to get me a few old catalogs if Im going to keep doing this.
On a side note the Thermistor in my yoke has disintegrated and the only spec is that its 700k cold according to the Sams manual.
Now trying to locate something that will work.
Old 08-02-2021, 09:48 AM
damen's Avatar
That thermistor is there to help keep the vertical size constant as the yoke heats up. I've seen them replaced with regular resistors and noticed no ill effects.
Old 08-02-2021, 06:24 PM
That’s what I’m going to do. It’ll be fine.
