Old 09-25-2021, 07:16 AM
kf4rca kf4rca is offline
VGA projectors
Anybody know anything about vga projectors?
They'll do composite video as well.
I picked one up at the local free public recycling bin that runs for about 2 minutes then goes into lamp and temp shutdown. Appears to be a fairly new model.
The fan doesn't sound like its up to speed to me.
Old 09-25-2021, 10:45 AM
Have you looked inside to see how dirty it is?
https://www.youtube.com/watch?v=NpooD1atmPs
Although I expect the fan would run faster if the filter is clogged.
Old 09-27-2021, 05:07 AM
djski djski is offline
You didn't mention brand or model but many of the better projectors have more than one fan and usually the only way to know is remove the covers.. If yours falls into that category, one could be binding and slowing down. It won't do its job effectively.
Old 09-27-2021, 06:17 AM
maxhifi's Avatar
maxhifi maxhifi is offline
If it is a DLP projector, it could be the color wheel making noise and not a fan.
Old 09-27-2021, 08:47 AM
Thanks for the replies. Its a Viewsonic and I think its a bad fan:
https://www.youtube.com/watch?v=jQ3WTngupLM
Old 09-27-2021, 08:53 PM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
A lot of these have a lifespan timer for the lamp. So even if the lamp is good, it may shut down simply because it's counted too many hours. Use the two minutes of run time you have to check the menus for anything about that. They usually don't hide it, there should be a reset somewhere.
As for the fan, you should be able to feel it blowing air near the lamp. They will also have air filters for the fans, ensure those are clean.
Old 09-28-2021, 07:03 AM
Thanks. I'll check for that. I took out 4 screws on the bottom and it still didn't want to come apart. Removing the lamp, I can see the fan is not clogged and spins pretty freely. Didn't see an air filter.
Old 09-29-2021, 09:31 PM
MadMan's Avatar
The Resident Brony
There's probably a second fan to cool the screen projecting thingy.
