Old 10-09-2021, 05:42 PM
Adam's Avatar
Adam Adam is offline
95 Lincoln Mark VIII
So, after working on my Continental all break (and still not solving whatever's wrong with it), I searched craigslist for something else I could use as a driver for a while, and came up with another Lincoln.
The paint is bad and the grille has been broken into many pieces and somebody tried to repair it with hot glue (lots of hot glue), but it only has 69K miles on it, and I've always thought these cars were kind of neat - they came with the 4-overhead cam, aluminum block version of the 4.6L V8.
Old 10-09-2021, 09:03 PM
dishdude's Avatar
dishdude dishdude is offline
Very nice.
Old 10-13-2021, 01:47 AM
MadMan's Avatar
MadMan MadMan is offline
The Resident Brony
Cool.
Old 10-13-2021, 11:01 AM
I owned a new '98 Mark VIII for 5 years. It ate ignition coils a couple of times, but no other problems I recall. Judging from replacement parts I saw listed online, air suspension bags could be another eventual failure point.
This car was when I stopped changing my own oil - too low to the ground, and I couldn't get over distrust of the air suspension even though it has a disable switch.
Old 10-13-2021, 08:45 PM
ESigma25 ESigma25 is offline
I was already missing my MN12 Thunderbird and now I'm missing it even more. Hope I can find another one.
Old 10-17-2021, 09:55 AM
Adam's Avatar
I put it up on ramps to change the oil - I have to do the same with my 84 Firebird (which is even lower). The hard part about changing the oil on this is getting the filter out, not unscrewing it from the engine, but actually removing it from the engine compartment afterwards. I couldn't come up with a method that didn't involve turning it upside-down and spilling oil everywhere.
The weather recently cooled down a bit, and it's hard to start in the morning when it's cold. The engine turns over easily enough, but it doesn't want to start, and then it idles a little rough for a few minutes, then it runs fine. - Opposite of my 83 Lincoln which runs great when you first start it, then starts missing and stalls after the engine warms up.
Old 10-17-2021, 04:55 PM
Highly recommend getting an oil filter relocation kit. My Thunderbird had one and it made the oil filter really easy to get to since it was moved in front of the engine pointing straight down.
Old 10-17-2021, 10:57 PM
MadMan's Avatar
The Resident Brony
A temperature sensor or slight vacuum leak. Ensure MAFS is clean.
Old 10-18-2021, 01:23 AM
SpaceAge's Avatar
SpaceAge SpaceAge is offline
My car has the oil filter up top and at the front… why isn’t every car like this? Say what you will about the Germans but they got this one right.
File Type: jpg FEC1C02D-DB4B-4E98-AF08-ECCF75742C69.jpg (91.9 KB, 15 views)
