Old 12-29-2021, 04:28 PM
peter scott's Avatar
peter scott peter scott is offline
The Queen's Christmas Message on 1937 HMV901
This was converted in a HUMAX set-top box and the 625 line output converted in an Aurora standards converter to 405 line 45MHz / 41.5MHz RF for connection to the aerial input of the HMV901.
https://youtu.be/QMHRO8Oijlw
Old 12-29-2021, 05:26 PM
stromberg67's Avatar
stromberg67 stromberg67 is offline
Old 12-29-2021, 08:02 PM
Very nice!
Old 12-30-2021, 02:29 PM
edison64's Avatar
edison64 edison64 is offline
THE A-1 WIRELESS MAN
Location: NW INDIANA THE MAPLE CITY LA PORTE (GO SLICERS)
Vary nice, thanks for sharing.
RCA VICTOR and its dealers bring you......
Old 12-31-2021, 01:45 PM
Wow that's a nice tv. Thanks for sharing Peter.
Old 01-05-2022, 01:11 AM
A 1937 TV? I didn't think they had fully functioning TV that early...
I know in the USA TV was experimental at that time but then when WWII broke out it was put on hold until 1946 or thereafter.
Are you sure it wasn't a 1940s TV?
Old 01-05-2022, 09:57 AM
There's a lot to learn - start here:
https://www.earlytelevision.org/prewar.html
Old 01-07-2022, 07:55 PM
dtvmcdonald's Avatar
I have a set identical
to that one, except a bit of cabinet woodwork,
a Marconi 702. These were the very very first generation of sets
for "non-experimental" TV broadcasts, from London. And yes, the first
official model year was 1937. The regular broadcasts started up in late 1936. At least one set, the Cossar 137T, is labeled as a 1936 model.
The 901/702 sets will display excellent picture and sound with a good strong signal. They don't have AGC, so you have to have the set and
antenna properly matched. In 1937 the limiting factor was not the transmitter, receiver, or the picture tube, but rather the camera tubes.
I have a working camera using 1938 technology and its damn hard to
adjust it to give a good picture, even with direct daylight illumination.
Its possible but unstable, even with rock (pun intended) stable power and sync genertor
Old 01-12-2022, 12:19 PM
See: http://www.nostalgiatech.co.uk/Vintagetech.htm
Peter
